Ga door naar hoofdinhoud
LG Front Load Washing Machine Drain Filter Replacement
  1. LG Front Load Washing Machine Drain Filter Replacement, Unclip the filter door: stap 1, afbeelding 1 van 2 LG Front Load Washing Machine Drain Filter Replacement, Unclip the filter door: stap 1, afbeelding 2 van 2
    • Unclip the filter door from its slot in the chassis and let it rest on the ground.
  2. LG Front Load Washing Machine Drain Filter Replacement, Drain the drain filter hose: stap 2, afbeelding 1 van 3 LG Front Load Washing Machine Drain Filter Replacement, Drain the drain filter hose: stap 2, afbeelding 2 van 3 LG Front Load Washing Machine Drain Filter Replacement, Drain the drain filter hose: stap 2, afbeelding 3 van 3
    • Place a bowl next to the device.
    • Pull the drain filter hose out of its slot in the chassis enough to lay over the bowl.
    • Remove the plug at the end of the drain filter hose to release excess water into the bowl.
    • During reassembly, re-plug the drain filter hose and thread it back through its slot in the chassis.
  3. LG Front Load Washing Machine Drain Filter Replacement, Remove the drain filter: stap 3, afbeelding 1 van 3 LG Front Load Washing Machine Drain Filter Replacement, Remove the drain filter: stap 3, afbeelding 2 van 3 LG Front Load Washing Machine Drain Filter Replacement, Remove the drain filter: stap 3, afbeelding 3 van 3
    • Twist the drain filter counterclockwise until it's fully disconnected from the chassis.
    • Remove the drain filter.
Conclusie
Repair didn’t go as planned? Ask our Answers community for help.
Bill Gilbert
30.797 Reputatie
213 handleidingen geschreven
iFixit Lid van iFixit
Staff
140 Leden
18.067 handleidingen geschreven
Één opmerking
I need to replace the clip door it fell off when we moved.
Maria Medina - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 5
Afgelopen 7 dagen: 24
Afgelopen 30 dagen: 122
Altijd: 1,356
