Inleiding
When encountering issues with the slider keyboard on your LG Enact (LG-VS890), such as keys becoming unresponsive or the slider mechanism not functioning properly, it may be time to consider replacing the keyboard. Over time and extended usage, the slider keyboard components can wear out or become damaged, leading to a less responsive or dysfunctional typing experience.
In this guide, we'll walk you through the steps to safely remove and replace the slider keyboard on your LG Enact. Remember to power off your device before starting this process to ensure a safe and effective keyboard replacement.
Wat je nodig hebt
Open the back cover by prying into the bottom tab with an iFixit opening tool.
Remove the three 1.2 mm screws from the speaker using a Phillips #00 screwdriver.
Remove the nine 1.2 mm screws from the midframe using a Phillips #00 screwdriver.
Unplug the four ports connected to the motherboard.
Disconnect the two wires on top of the battery.
Disconnect the two wires under the battery.
Gently peel off the orange strip attached to the charging port using an iFixit opening pick.
Gently remove the blue metal plate using an iFixit opening pick.
Gently remove the black plastic from inside the battery compartment.
Één andere persoon heeft deze handleiding voltooid.
