Ga door naar hoofdinhoud
LG Dare Logic Board Replacement
Wat je nodig hebt
  1. LG Dare Logic Board Replacement, Battery: stap 1, afbeelding 1 van 2 LG Dare Logic Board Replacement, Battery: stap 1, afbeelding 2 van 2
    • Remove the back cover by firmly pressing against the raised lip on the back panel. Slide the cover towards the top of the phone.
    Vraag FixBot
    Voeg opmerking toe
  2. LG Dare Logic Board Replacement: stap 2, afbeelding 1 van 3 LG Dare Logic Board Replacement: stap 2, afbeelding 2 van 3 LG Dare Logic Board Replacement: stap 2, afbeelding 3 van 3
    • Remove the battery by placing your fingernail or a opening tool in the recessed edge and lift the battery out.
    Vraag FixBot
    Voeg opmerking toe
  3. LG Dare Logic Board Replacement, Logic Board: stap 3, afbeelding 1 van 2 LG Dare Logic Board Replacement, Logic Board: stap 3, afbeelding 2 van 2
    • Use the #00 screwdriver to remove the six 4mm phillips screws located around the edges of the phone.
    Vraag FixBot
    Voeg opmerking toe
  4. LG Dare Logic Board Replacement: stap 4, afbeelding 1 van 3 LG Dare Logic Board Replacement: stap 4, afbeelding 2 van 3 LG Dare Logic Board Replacement: stap 4, afbeelding 3 van 3
    • Lift the back plastic cover off by moving the opening tool around the edges of the phone.
    • Wedging the opening tool in several places on the bottom of the phone will help release small tabs that hold the back to the front frame.
    • The side buttons may fall out when removing the back plastic.
    Vraag FixBot
    Voeg opmerking toe
  5. LG Dare Logic Board Replacement: stap 5, afbeelding 1 van 3 LG Dare Logic Board Replacement: stap 5, afbeelding 2 van 3 LG Dare Logic Board Replacement: stap 5, afbeelding 3 van 3
    • Pull off the back plastic panel.
    • Remove the buttons from the edge of the frame. The buttons are [lock], [volume control], [speaker], and [camera].
    Vraag FixBot
    Voeg opmerking toe
  6. LG Dare Logic Board Replacement: stap 6, afbeelding 1 van 1
    • Disconnect the three ribbon connectors from the motherboard.
    Vraag FixBot
    Voeg opmerking toe
  7. LG Dare Logic Board Replacement: stap 7, afbeelding 1 van 3 LG Dare Logic Board Replacement: stap 7, afbeelding 2 van 3 LG Dare Logic Board Replacement: stap 7, afbeelding 3 van 3
    • Remove the LED.
    • Remove the camera connector.
    • Remove the camera sensor from the logic board. Squeeze the sides of the camera sensor firmly and pull straight up.
    Vraag FixBot
    Voeg opmerking toe
  8. LG Dare Logic Board Replacement: stap 8, afbeelding 1 van 1
    • Open the USB port cover.
    Vraag FixBot
    Voeg opmerking toe
  9. LG Dare Logic Board Replacement: stap 9, afbeelding 1 van 3 LG Dare Logic Board Replacement: stap 9, afbeelding 2 van 3 LG Dare Logic Board Replacement: stap 9, afbeelding 3 van 3
    • Use the opening tool to lift up the green logic board in all areas and remove it.
    • The logic board may require some force to remove because it is taped to the plastic frame.
    • When removing the logic board, be careful not to tear any of the ribbon cables or side buttons.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
To re-assemble your device, follow these instructions in reverse order.
Haoyan Huang
151 Reputatie
4 handleidingen geschreven
Cal Poly, Team 9-4, Regan Winter 2012 Lid van Cal Poly, Team 9-4, Regan Winter 2012
CPSU-REGAN-W12S9G4
5 Leden
21 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 34
Altijd: 2,590
