Wat je nodig hebt
Insert the plastic opener into the slot at the top of the device.
Apply gentle pressure with the plastic tool to pop the back case off.
Use a screwdriver and corresponding bit to remove the six 2mm screws that are located along the edge of the rear case. Set the screws aside.
Use a screwdriver and corresponding bit to remove the two 3mm screws that attach the motherboard to the front case. Set the screws aside
Use a screwdriver and corresponding bit to remove the four 1mm screws. Set the screws aside.
Use a tool to pry open the LCD display. Remove the display and the circuit board that it's connected to.
Één andere persoon heeft deze handleiding voltooid.
