Ga door naar hoofdinhoud
LG BP220 Motherboard Replacement
Wat je nodig hebt
  1. LG BP220 Motherboard Replacement, Motherboard: stap 1, afbeelding 1 van 2 LG BP220 Motherboard Replacement, Motherboard: stap 1, afbeelding 2 van 2
    • Ensure the device is unplugged to prevent shocks.
    • Remove the three black 3/16” Phillips #2 screws from the backside of the player.
    • With the backside (audio/video jacks) facing you, lift the part of the cover closer to you and pull until it is off.
    Vraag FixBot
    Voeg opmerking toe
  2. LG BP220 Motherboard Replacement: stap 2, afbeelding 1 van 3 LG BP220 Motherboard Replacement: stap 2, afbeelding 2 van 3 LG BP220 Motherboard Replacement: stap 2, afbeelding 3 van 3
    • Unhinge the tabs that attach the front panel to the unit:
    • Two tabs on the disc drive
    • Two tabs on the left and right side of the player
    • Be careful when handling these tabs. They are very fragile and can be easily broken.
    • Three tabs on the underside of the player
    • Pull panel away from case.
    • If the panel does not come off right away, be sure to check if tabs have inadvertently switched back to their locked position.
    Vraag FixBot
    Voeg opmerking toe
  3. LG BP220 Motherboard Replacement: stap 3, afbeelding 1 van 1
    • Using your fingers, pull the three tape-like cables to disconnect the disc drive from the green motherboard.
    Vraag FixBot
    Voeg opmerking toe
  4. LG BP220 Motherboard Replacement: stap 4, afbeelding 1 van 2 LG BP220 Motherboard Replacement: stap 4, afbeelding 2 van 2
    • Remove the two black 3/16” Phillips #2 mounting screws from the left and right side of the disc drive.
    • With the front side facing you lift the front of disc drive, slide it toward you and pull out to remove.
    Vraag FixBot
    Voeg opmerking toe
  5. LG BP220 Motherboard Replacement: stap 5, afbeelding 1 van 3 LG BP220 Motherboard Replacement: stap 5, afbeelding 2 van 3 LG BP220 Motherboard Replacement: stap 5, afbeelding 3 van 3
    • Detach the power supply cord from the brown motherboard by pushing the locking clip on the connector, and pulling out.
    • The connector may be difficult to remove. Wiggling it while pulling out may help release it.
    • Remove the power cord from the panel by carefully sliding it upwards from its seating.
    Vraag FixBot
    Voeg opmerking toe
  6. LG BP220 Motherboard Replacement: stap 6, afbeelding 1 van 2 LG BP220 Motherboard Replacement: stap 6, afbeelding 2 van 2
    • Remove the two black 3/16” Phillips #2 screws from the backside of the player.
    • One screw inbetween the audio/video jacks
    • One screw to the bottom right of the audio/video jacks
    • With the backside facing you, pull the bottom of the panel towards you and lift to remove it.
    Vraag FixBot
    Voeg opmerking toe
  7. LG BP220 Motherboard Replacement: stap 7, afbeelding 1 van 2 LG BP220 Motherboard Replacement: stap 7, afbeelding 2 van 2
    • Handle the motherboards with care. They are fragile.
    • Beware of the capacitors as they may shock you when touched.
    • Remove the the two silver 3/16” Phillips #2 screws from the green motherboard.
    • Remove the one black 3/16” Phillips #2 screw from the brown motherboard
    • Use both hands to carefully lift the motherboard unit away from the player.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
6 andere personen hebben deze handleiding voltooid.
Bart Quicho
520 Reputatie
3 handleidingen geschreven
UW Tacoma, Team 1-1, Rose Winter 2015 Lid van UW Tacoma, Team 1-1, Rose Winter 2015
UWT-ROSE-W15S1G1
4 Leden
1Gids Commentaar
I need Ic htc lm37102 which is on this lg motherboard. How can i get that. I am not able to find
Email Id abhishek.mishra171983@gmail.com
Please let me know if you have this rgulator ic on my email id.
Thnx
Abhishek
Abhishek Mishra - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 55
Altijd: 5,312
