Ga door naar hoofdinhoud
LCD Screen Replacement
Wat je nodig hebt
    1. LCD Screen  Replacement, Battery Door: stap 1, afbeelding 1 van 1
      • Remove the M3 x 4mm screws from the bottom of your device as indicated by the picture. using the Philips Head J0 Screw Driver Bit .
      Vraag FixBot
      Voeg opmerking toe
    2. LCD Screen  Replacement: stap 2, afbeelding 1 van 1
      • Use your Philips Head Screwdriver to remove the M3 x 4mm screws from the left side of the device as indicated by the pictures.
      Vraag FixBot
      Voeg opmerking toe
    3. LCD Screen  Replacement: stap 3, afbeelding 1 van 1
      • Use your Philips Head Screwdriver to remove the M3 x 4mm screws from the right side of the device as indicated by the pictures.
      Vraag FixBot
      Voeg opmerking toe
    4. LCD Screen  Replacement: stap 4, afbeelding 1 van 2 LCD Screen  Replacement: stap 4, afbeelding 2 van 2
      • Use your Philips Head Screwdriver to remove the M3 x 4mm screws from the camera flash lid as indicated by the picture.
      • Remove the plastic cover from the flash lid by gentle pulling them apart or using the plastic opening tool.
      Vraag FixBot
      Voeg opmerking toe
    5. LCD Screen  Replacement: stap 5, afbeelding 1 van 1
      • Fold the lid down in order to access and remove the final M3 x 4mm screw using your Philips Head Screwdriver.
      Vraag FixBot
      Voeg opmerking toe
    6. LCD Screen  Replacement: stap 6, afbeelding 1 van 3 LCD Screen  Replacement: stap 6, afbeelding 2 van 3 LCD Screen  Replacement: stap 6, afbeelding 3 van 3
      • Use the plastic opening tool to pry the back and front casings of the camera apart.
      • Once pried apart use your hands to pull off the back plate of the camera.
      • You will need to apply a little bit of force to remove the back plate.
      Vraag FixBot
      Voeg opmerking toe
    7. LCD Screen  Replacement: stap 7, afbeelding 1 van 3 LCD Screen  Replacement: stap 7, afbeelding 2 van 3 LCD Screen  Replacement: stap 7, afbeelding 3 van 3
      • Once the back plate is removed twist the battery cover clockwise and it should easily dislodge.
      Vraag FixBot
      Voeg opmerking toe
    1. LCD Screen  Replacement, LCD Screen: stap 8, afbeelding 1 van 3 LCD Screen  Replacement, LCD Screen: stap 8, afbeelding 2 van 3 LCD Screen  Replacement, LCD Screen: stap 8, afbeelding 3 van 3
      • Gently pull the tab out of the motherboard and then the LCD screen should easily be removed.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Colton Lancsarics
731 Reputatie
6 handleidingen geschreven
USF Tampa, Team 3-2, Sullivan Spring 2016 Lid van USF Tampa, Team 3-2, Sullivan Spring 2016
USFT-SULLIVAN-S16S3G2
4 Leden
12 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 20
Altijd: 986
