Ga door naar hoofdinhoud
LCD Replacement
  1. LCD Replacement, Rear Cover: stap 1, afbeelding 1 van 1
    • First ensure your laptop is turned off and check if you have the necessary tools
    Vraag FixBot
    Voeg opmerking toe
  2. LCD Replacement: stap 2, afbeelding 1 van 2 LCD Replacement: stap 2, afbeelding 2 van 2
    • All screws are identified by circles. Pay special attention to the yellow circles, as the rubber feet hide screws.
    Vraag FixBot
    Voeg opmerking toe
  3. LCD Replacement: stap 3, afbeelding 1 van 3 LCD Replacement: stap 3, afbeelding 2 van 3 LCD Replacement: stap 3, afbeelding 3 van 3
    • With the opening tool, remove a rubber foot.
    • For this action you will have to exert some force, because the foot is glued with a resistant glue.
    Vraag FixBot
    Voeg opmerking toe
  4. LCD Replacement: stap 4, afbeelding 1 van 1
    • Remove all screws with a Philips screwdriver PH1
    • All screws are the same so don't worry about identifying them.
    Vraag FixBot
    Voeg opmerking toe
  5. LCD Replacement: stap 5, afbeelding 1 van 3 LCD Replacement: stap 5, afbeelding 2 van 3 LCD Replacement: stap 5, afbeelding 3 van 3
    • With the plastic tool, insert between the plastics and gently pry open.
    • With your fingers continue to force open the bottom cover on the side indicated in the figure.
    • You will feel and hear several clicks, perfectly normal, nothing is breaking. Remove the cover completely.
    Vraag FixBot
    Voeg opmerking toe
  6. LCD Replacement: stap 6, afbeelding 1 van 1
    • Finally, we have the laptop open and ready to replace most of its components. Look elsewhere on how to replace a component.
    • To close the laptop just follow this guide in reverse.
    Vraag FixBot
    Voeg opmerking toe
    • Insert instructions here.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
To reassemble your device, follow the previous steps in inverse order.
Met dank aan deze vertalers:
pt en
100%
David helpt ons de wereld te repareren! Doe je mee?
Begin met vertalen ›
Nelson Oliveira
741 Reputatie
4 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 5
Afgelopen 7 dagen: 15
Afgelopen 30 dagen: 53
Altijd: 473
