Ga door naar hoofdinhoud
Kurio Xtreme Power/Volume Buttons Replacement
Wat je nodig hebt
  1. Kurio Xtreme Power/Volume Buttons Replacement, Back Panel: stap 1, afbeelding 1 van 1
    • Remove the rubber case by beginning to peel from one of the top corners and continue peeling until the cover is completely removed.
    Vraag FixBot
    Voeg opmerking toe
  2. Kurio Xtreme Power/Volume Buttons Replacement: stap 2, afbeelding 1 van 2 Kurio Xtreme Power/Volume Buttons Replacement: stap 2, afbeelding 2 van 2
    • Unscrew the four 4 mm black screws using a Phillips #000 screw driver.
    • There are two screws on each side of the device (four total).
    Vraag FixBot
    Voeg opmerking toe
  3. Kurio Xtreme Power/Volume Buttons Replacement: stap 3, afbeelding 1 van 3 Kurio Xtreme Power/Volume Buttons Replacement: stap 3, afbeelding 2 van 3 Kurio Xtreme Power/Volume Buttons Replacement: stap 3, afbeelding 3 van 3
    • Insert the plastic opening tool in between the edges of the blue front casing and black back casing.
    • Slide the plastic opening tool around the perimeter of the device. This may require that you repeatedly run the opening tool up and down the edges of the device.
    • Be sure not to break any of the plastic clamps along the edges of the device when removing the back cover.
    • Carefully lift the back panel off of the rest of the device.
    Vraag FixBot
    Voeg opmerking toe
  4. Kurio Xtreme Power/Volume Buttons Replacement, Power/Volume Buttons: stap 4, afbeelding 1 van 1
    • Remove the three 4 mm screws on the motherboard with a Phillips #000 screwdriver.
    Vraag FixBot
    Voeg opmerking toe
  5. Kurio Xtreme Power/Volume Buttons Replacement: stap 5, afbeelding 1 van 2 Kurio Xtreme Power/Volume Buttons Replacement: stap 5, afbeelding 2 van 2
    • Remove the orange data display ribbon wire above the battery by prying open the ZIF connector with the plastic opening tool.
    Vraag FixBot
    Voeg opmerking toe
  6. Kurio Xtreme Power/Volume Buttons Replacement: stap 6, afbeelding 1 van 2 Kurio Xtreme Power/Volume Buttons Replacement: stap 6, afbeelding 2 van 2
    • Remove the orange data display ribbon wire to the left of the battery by prying open the ZIF connector with the plastic opening tool.
    Vraag FixBot
    Voeg opmerking toe
  7. Kurio Xtreme Power/Volume Buttons Replacement: stap 7, afbeelding 1 van 1
    • Remove the speakers out of the plastic molds by lifting up the black and red wires.
    • Be careful not to disconnect the black and red wires from the motherboard.
    Vraag FixBot
    Voeg opmerking toe
  8. Kurio Xtreme Power/Volume Buttons Replacement: stap 8, afbeelding 1 van 2 Kurio Xtreme Power/Volume Buttons Replacement: stap 8, afbeelding 2 van 2
    • Remove the motherboard by lifting it out of the casing. Set it upside down below the casing.
    • The motherboard will still be connected to the battery and the speakers.
    Vraag FixBot
    Voeg opmerking toe
  9. Kurio Xtreme Power/Volume Buttons Replacement: stap 9, afbeelding 1 van 3 Kurio Xtreme Power/Volume Buttons Replacement: stap 9, afbeelding 2 van 3 Kurio Xtreme Power/Volume Buttons Replacement: stap 9, afbeelding 3 van 3
    • Remove the volume buttons and/or power button by soldering them at their bases.
    • Volume down
    • Volume up
    • Power
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Mallory Myers
1.190 Reputatie
7 handleidingen geschreven
Baylor, Team 6-10, Williams Fall 2015 Lid van Baylor, Team 6-10, Williams Fall 2015
BU-WILLIAMS-F15S6G10
3 Leden
14 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 18
Altijd: 1,129
