Inleiding
Follow this guide to replace the motherboard in your Kurio Xtreme. Before you begin, make sure that you have a soldering iron and know how to use it.
Wat je nodig hebt
Remove the rubber case by beginning to peel from one of the top corners and continue peeling until the cover is completely removed.
Insert the plastic opening tool in between the edges of the blue front casing and black back casing.
Slide the plastic opening tool around the perimeter of the device. This may require that you repeatedly run the opening tool up and down the edges of the device.
Carefully lift the back panel off of the rest of the device.
Één andere persoon heeft deze handleiding voltooid.
