Ga door naar hoofdinhoud
Kurio Xtreme Motherboard Replacement
Wat je nodig hebt
  1. Kurio Xtreme Motherboard Replacement, Back Panel: stap 1, afbeelding 1 van 1
    • Remove the rubber case by beginning to peel from one of the top corners and continue peeling until the cover is completely removed.
  2. Kurio Xtreme Motherboard Replacement: stap 2, afbeelding 1 van 2 Kurio Xtreme Motherboard Replacement: stap 2, afbeelding 2 van 2
    • Unscrew the four 4 mm black screws using a Phillips #000 screw driver.
    • There are two screws on each side of the device (four total).
  3. Kurio Xtreme Motherboard Replacement: stap 3, afbeelding 1 van 3 Kurio Xtreme Motherboard Replacement: stap 3, afbeelding 2 van 3 Kurio Xtreme Motherboard Replacement: stap 3, afbeelding 3 van 3
    • Insert the plastic opening tool in between the edges of the blue front casing and black back casing.
    • Slide the plastic opening tool around the perimeter of the device. This may require that you repeatedly run the opening tool up and down the edges of the device.
    • Be sure not to break any of the plastic clamps along the edges of the device when removing the back cover.
    • Carefully lift the back panel off of the rest of the device.
  4. Kurio Xtreme Motherboard Replacement, Motherboard: stap 4, afbeelding 1 van 1
    • Unscrew the three 4 mm screws with a Phillips #000 screwdriver.
  5. Kurio Xtreme Motherboard Replacement: stap 5, afbeelding 1 van 2 Kurio Xtreme Motherboard Replacement: stap 5, afbeelding 2 van 2
    • Remove the orange data display ribbon wire above the battery by prying open the ZIF connector with the plastic opening tool.
  6. Kurio Xtreme Motherboard Replacement: stap 6, afbeelding 1 van 2 Kurio Xtreme Motherboard Replacement: stap 6, afbeelding 2 van 2
    • Remove the orange data display ribbon wire to the left of the battery by prying open the ZIF connector with the plastic opening tool.
  7. Kurio Xtreme Motherboard Replacement: stap 7, afbeelding 1 van 3 Kurio Xtreme Motherboard Replacement: stap 7, afbeelding 2 van 3 Kurio Xtreme Motherboard Replacement: stap 7, afbeelding 3 van 3
    • Remove the 7 wires connected to the motherboard by soldering the ends that connect them to the motherboard.
    • 2 pairs of red and black speaker wires (4 wires total)
    • 1 pair of red and black battery wires (2 wires total)
    • 1 gray ground wire
    • The soldering iron gets very hot and may injure you if exposed to your skin.
  8. Kurio Xtreme Motherboard Replacement: stap 8, afbeelding 1 van 1
    • Remove the motherboard by lifting it out of the casing.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Mallory Myers
1.190 Reputatie
7 handleidingen geschreven
Baylor, Team 6-10, Williams Fall 2015 Lid van Baylor, Team 6-10, Williams Fall 2015
BU-WILLIAMS-F15S6G10
3 Leden
14 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 8
Altijd: 925
