Ga door naar hoofdinhoud
Kurio Xtreme Camera Replacement
Wat je nodig hebt
    1. Kurio Xtreme Camera Replacement, Back Panel: stap 1, afbeelding 1 van 1
      • Remove the rubber case by beginning to peel from one of the top corners and continue peeling until the cover is completely removed.
      Vraag FixBot
      Voeg opmerking toe
    2. Kurio Xtreme Camera Replacement: stap 2, afbeelding 1 van 2 Kurio Xtreme Camera Replacement: stap 2, afbeelding 2 van 2
      • Unscrew the four 4 mm black screws using a Phillips #000 screw driver.
      • There are two screws on each side of the device (four total).
      Vraag FixBot
      Voeg opmerking toe
    3. Kurio Xtreme Camera Replacement: stap 3, afbeelding 1 van 3 Kurio Xtreme Camera Replacement: stap 3, afbeelding 2 van 3 Kurio Xtreme Camera Replacement: stap 3, afbeelding 3 van 3
      • Insert the plastic opening tool in between the edges of the blue front casing and black back casing.
      • Slide the plastic opening tool around the perimeter of the device. This may require that you repeatedly run the opening tool up and down the edges of the device.
      • Be sure not to break any of the plastic clamps along the edges of the device when removing the back cover.
      • Carefully lift the back panel off of the rest of the device.
      Vraag FixBot
      Voeg opmerking toe
    1. Kurio Xtreme Camera Replacement, Camera: stap 4, afbeelding 1 van 1
      • Remove the flat-topped connector that connects the cameras to the motherboard by using the plastic opening tool to pry up on each side.
      Vraag FixBot
      Voeg opmerking toe
    2. Kurio Xtreme Camera Replacement: stap 5, afbeelding 1 van 3 Kurio Xtreme Camera Replacement: stap 5, afbeelding 2 van 3 Kurio Xtreme Camera Replacement: stap 5, afbeelding 3 van 3
      • Remove the smaller, front facing camera by lifting up on the attached ribbon cable.
      • Remove the larger, rear facing camera by lifting up on the attached ribbon cable.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Mallory Myers
1.190 Reputatie
7 handleidingen geschreven
Baylor, Team 6-10, Williams Fall 2015 Lid van Baylor, Team 6-10, Williams Fall 2015
BU-WILLIAMS-F15S6G10
3 Leden
14 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 29
Altijd: 465
