Ga door naar hoofdinhoud
Kurio Xtreme Battery Replacement
Wat je nodig hebt
  1. Kurio Xtreme Battery Replacement, Back Panel: stap 1, afbeelding 1 van 1
    • Remove the rubber case by beginning to peel from one of the top corners and continue peeling until the cover is completely removed.
  2. Kurio Xtreme Battery Replacement: stap 2, afbeelding 1 van 2 Kurio Xtreme Battery Replacement: stap 2, afbeelding 2 van 2
    • Unscrew the four 4 mm black screws using a Phillips #000 screw driver.
    • There are two screws on each side of the device (four total).
  3. Kurio Xtreme Battery Replacement: stap 3, afbeelding 1 van 3 Kurio Xtreme Battery Replacement: stap 3, afbeelding 2 van 3 Kurio Xtreme Battery Replacement: stap 3, afbeelding 3 van 3
    • Insert the plastic opening tool in between the edges of the blue front casing and black back casing.
    • Slide the plastic opening tool around the perimeter of the device. This may require that you repeatedly run the opening tool up and down the edges of the device.
    • Be sure not to break any of the plastic clamps along the edges of the device when removing the back cover.
    • Carefully lift the back panel off of the rest of the device.
  4. Kurio Xtreme Battery Replacement, Battery: stap 4, afbeelding 1 van 2 Kurio Xtreme Battery Replacement, Battery: stap 4, afbeelding 2 van 2
    • Disconnect the black and red wires from the motherboard by soldering the ends that are connected to the motherboard.
    • The soldering iron gets very hot and may injure you if exposed to your skin.
  5. Kurio Xtreme Battery Replacement: stap 5, afbeelding 1 van 2 Kurio Xtreme Battery Replacement: stap 5, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    Plastic Cards
    $2.99
    Koop
    • Slide iFixit's Plastic Card tool or a credit card under the battery to remove the glue that is holding it in place.
    • Be patient and gentle. The glue is strong and may take up to 30 seconds to remove.
    • Carefully lift the battery out of the device.
Conclusie
Mallory Myers
1.190 Reputatie
7 handleidingen geschreven
Baylor, Team 6-10, Williams Fall 2015 Lid van Baylor, Team 6-10, Williams Fall 2015
BU-WILLIAMS-F15S6G10
3 Leden
14 handleidingen geschreven
2 opmerkingen
j ai changé de batterie mais la batterie ne charge pas. est ce que c ets parce qu un des deux fils serait mal soudé?
j-p1955 - Antwoord
Does it have a certain battery or can a different battery fit?
Nikki Gilliard - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 7
Altijd: 3,955
