Deze handleiding heeft recentere wijzigingen. Schakel over naar de nieuwste niet-geverifieerde versie.
Inleiding
Accessing the battery is straight-forward, but the replacement requires soldering, and that can be tricky. Soldering involves melting two pieces of metal together so that they become one piece. Replacing the battery should prevent the Kurio 7 from malfunctioning.
Wat je nodig hebt
Use a credit card, or other thin object, to separate the battery from the screen.
Desolder, or separate using the desoldering braid, the marked areas on the motherboard to remove the old battery.
Refer to our soldering guide on how to solder and desolder.
Solder in the new battery. To reassemble your device, follow these instructions in reverse order.
