Ga door naar hoofdinhoud
Koosh Vortex Tornado Loading Spring Replacement
Wat je nodig hebt
  1. Koosh Vortex Tornado Loading Spring Replacement, Barrel Shield Spring: stap 1, afbeelding 1 van 1
    • Remove the fourteen 15 mm Phillips #1 screws on the side of the body.
    Vraag FixBot
    Voeg opmerking toe
  2. Koosh Vortex Tornado Loading Spring Replacement: stap 2, afbeelding 1 van 1
    • Pull the halves of the toy gun apart to show the inside. Set the left half aside (all of the inside components are on the right half).
    Vraag FixBot
    Voeg opmerking toe
  3. Koosh Vortex Tornado Loading Spring Replacement: stap 3, afbeelding 1 van 1
    • Using a spudger, unhook the barrel shield's spring from the right half of the toy gun. One side should still be connected to the shield barrel shield.
    Vraag FixBot
    Voeg opmerking toe
  4. Koosh Vortex Tornado Loading Spring Replacement, Trigger: stap 4, afbeelding 1 van 1
    • Slide the barrel shield and shield slide off of the gun and set aside.
    Vraag FixBot
    Voeg opmerking toe
  5. Koosh Vortex Tornado Loading Spring Replacement: stap 5, afbeelding 1 van 1
    • Slide the rubber ring off of the barrel and set it aside.
    Vraag FixBot
    Voeg opmerking toe
  6. Koosh Vortex Tornado Loading Spring Replacement: stap 6, afbeelding 1 van 1
    • Lift the yellow trigger from its pin and set aside.
    Vraag FixBot
    Voeg opmerking toe
  7. Koosh Vortex Tornado Loading Spring Replacement, Loading Spring: stap 7, afbeelding 1 van 1
    • Use a Phillips #1 screwdriver to unscrew the two 12 mm long washer head screws from the yellow loading bar lever.
    Vraag FixBot
    Voeg opmerking toe
  8. Koosh Vortex Tornado Loading Spring Replacement: stap 8, afbeelding 1 van 1
    • Lift the yellow lever bar out of place and set aside.
    Vraag FixBot
    Voeg opmerking toe
  9. Koosh Vortex Tornado Loading Spring Replacement: stap 9, afbeelding 1 van 1
    • Use a Phillips #1 Screwdriver to unscrew the six 10 mm long screws from the central firing assembly.
    • Use Phillips #1 Screwdriver to unscrew the four 9 mm long screws from the central firing assembly.
    Vraag FixBot
    Voeg opmerking toe
  10. Koosh Vortex Tornado Loading Spring Replacement: stap 10, afbeelding 1 van 1
    • Pull the shell of the central firing assembly aside off (contains the loading spring).
    Vraag FixBot
    Voeg opmerking toe
  11. Koosh Vortex Tornado Loading Spring Replacement: stap 11, afbeelding 1 van 2 Koosh Vortex Tornado Loading Spring Replacement: stap 11, afbeelding 2 van 2
    • Open the back side of the central firing assembly apart to expose the loading spring. Remove it, and change it with your desired spring.
    • The two sides cannot be fully separated due to a pin holding the yellow collar tightly together.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Lingbin Meng
204 Reputatie
2 handleidingen geschreven
IUPUI, Team 2-4, Harley Spring 2016 Lid van IUPUI, Team 2-4, Harley Spring 2016
IUPUI-HARLEY-S16S2G4
4 Leden
3 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 6
Afgelopen 7 dagen: 22
Afgelopen 30 dagen: 76
Altijd: 1,093
