Ga door naar hoofdinhoud
Kodak Easyshare C813 Shutter Button Replacement
Wat je nodig hebt
  1. Kodak Easyshare C813 Shutter Button Replacement, Battery: stap 1, afbeelding 1 van 1
    • Turn off camera by firmly pressing the power button that is located on the top of the camera near the selector dial.
  2. Kodak Easyshare C813 Shutter Button Replacement: stap 2, afbeelding 1 van 3 Kodak Easyshare C813 Shutter Button Replacement: stap 2, afbeelding 2 van 3 Kodak Easyshare C813 Shutter Button Replacement: stap 2, afbeelding 3 van 3
    • Press thumb firmly on battery door and slide it in the direction of the arrow.
    • Lift thumb allowing the door to swing open.
  3. Kodak Easyshare C813 Shutter Button Replacement, Back Cover: stap 3, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    Anti-Static Wrist Strap
    $7.95
    Koop
  4. Kodak Easyshare C813 Shutter Button Replacement: stap 4, afbeelding 1 van 1
    • Turn the camera off by firmly pressing the power button located on top of the camera.
  5. Kodak Easyshare C813 Shutter Button Replacement: stap 5, afbeelding 1 van 3 Kodak Easyshare C813 Shutter Button Replacement: stap 5, afbeelding 2 van 3 Kodak Easyshare C813 Shutter Button Replacement: stap 5, afbeelding 3 van 3
    • Locate the 7 screws holding the back cover on.
    • Three screws are located on the bottom of the camera.
    • Two screws are located on the side shown in the photograph.
    • Two final screws are located on the opposite side shown in the photograph.
  6. Kodak Easyshare C813 Shutter Button Replacement: stap 6, afbeelding 1 van 3 Kodak Easyshare C813 Shutter Button Replacement: stap 6, afbeelding 2 van 3 Kodak Easyshare C813 Shutter Button Replacement: stap 6, afbeelding 3 van 3
    Phillips #00 Screwdriver
    $5.49
    Koop
    • Remove all 7 screws:
    • Hold the camera firmly with one hand so that you can still see a screw.
    • Place the Philips 00(Found here)screwdriver into the screw.
    • Turn the screwdriver to the left until it is free.
    • Repeat for the remaining screws.
  7. Kodak Easyshare C813 Shutter Button Replacement: stap 7, afbeelding 1 van 3 Kodak Easyshare C813 Shutter Button Replacement: stap 7, afbeelding 2 van 3 Kodak Easyshare C813 Shutter Button Replacement: stap 7, afbeelding 3 van 3
    • Use plastic opening tools to slightly open the side of the case.
    • Insert a plastic opening tool and apply pressure to the internal three tabs at the top.
    • The first two are near the words "3X Optical Zoom".
    • The third is near the shutter button.
  8. Kodak Easyshare C813 Shutter Button Replacement: stap 8, afbeelding 1 van 3 Kodak Easyshare C813 Shutter Button Replacement: stap 8, afbeelding 2 van 3 Kodak Easyshare C813 Shutter Button Replacement: stap 8, afbeelding 3 van 3
    • Gently pull apart the back cover from the rest of the camera.
    • Make sure there are no more screws or tabs keeping the cover on.
    • Use the plastic opening tool to separate any sides still closely connected.
  9. Kodak Easyshare C813 Shutter Button Replacement, Front Cover: stap 9, afbeelding 1 van 2 Kodak Easyshare C813 Shutter Button Replacement, Front Cover: stap 9, afbeelding 2 van 2
    • Open the battery door.
    The battery door on my easyshare c813 is broken. How can i get a replacement door?
    paul chadwell - Antwoord
  10. Kodak Easyshare C813 Shutter Button Replacement: stap 10, afbeelding 1 van 3 Kodak Easyshare C813 Shutter Button Replacement: stap 10, afbeelding 2 van 3 Kodak Easyshare C813 Shutter Button Replacement: stap 10, afbeelding 3 van 3
    • Use the plastic opening tool to lift the casing around the shutter button.
    • Gently remove the front cover from the device.
  11. Kodak Easyshare C813 Shutter Button Replacement: stap 11, afbeelding 1 van 1
    • Do not touch the terminals shown in the photo. These link to the capacitor which could shock you if not discharged.
    • To discharge the capacitor follow this guide.
  12. Kodak Easyshare C813 Shutter Button Replacement, Shutter Button: stap 12, afbeelding 1 van 2 Kodak Easyshare C813 Shutter Button Replacement, Shutter Button: stap 12, afbeelding 2 van 2
    • The shutter button is held on to the front cover by three screws
    • Hold the shutter button in place
    • Use a Philips 00 screwdriver to remove the screws.
    • Careful that the power and flash button do not fall off
  13. Kodak Easyshare C813 Shutter Button Replacement: stap 13, afbeelding 1 van 3 Kodak Easyshare C813 Shutter Button Replacement: stap 13, afbeelding 2 van 3 Kodak Easyshare C813 Shutter Button Replacement: stap 13, afbeelding 3 van 3
    • Keep the shutter button in place while removing the circular metal plate
    • Remove the shutter button by allowing it to fall into your hand
  14. Kodak Easyshare C813 Shutter Button Replacement: stap 14, afbeelding 1 van 3 Kodak Easyshare C813 Shutter Button Replacement: stap 14, afbeelding 2 van 3 Kodak Easyshare C813 Shutter Button Replacement: stap 14, afbeelding 3 van 3
    Heavy-Duty Spudger
    Koop
    • Hold down the shutter button portion of the selector dial
    • Press down the red tabs and slowly relieve pressure on the shutter button
    • Press down on the center red stick
    • Careful not to lose the spring
    • Tool shown is Found here
  15. Kodak Easyshare C813 Shutter Button Replacement: stap 15, afbeelding 1 van 1
    • If cleaning, remove dirt from button
    • When putting back together, the button should be be oriented so that the green automatic mode points towards the power button.
Conclusie
Susan Marano
336 Reputatie
7 handleidingen geschreven
Cal Poly, Team 24-22, Regan Spring 2010 Lid van Cal Poly, Team 24-22, Regan Spring 2010
CPSU-REGAN-S10S24G22
4 Leden
20 handleidingen geschreven
Één opmerking
does anybody know how the pins works on the surface mounted shutter switch button on the PCB? this would be very helpful thanks!
random - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 9
Altijd: 7,571
