Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Turn off camera by firmly pressing the power button that is located on the top of the camera near the mode selector dial.
Locate battery compartment on bottom of camera and slide open by applying pressure in the direction of the arrow.
Locate memory card slot and insert memory card by inserting the gold terminals first.
Apply pressure into you feel it lock into place.
Note: To remove a memory card, apply pressure down until you feel it click. Then it should pop up and you can just pull it up.
Return the battery door to its formerly closed position.
Turn on camera.
If you encounter a problem refer to your memory card, reference: Camera Memory Problems
Één andere persoon heeft deze handleiding voltooid.
