Ga door naar hoofdinhoud
Kodak EasyShare LS743 Microphone Replacement
Wat je nodig hebt
  1. Kodak EasyShare LS743 Microphone Replacement, Battery: stap 1, afbeelding 1 van 1
    • Using your fingernail, open the battery cover.
  2. Kodak EasyShare LS743 Microphone Replacement: stap 2, afbeelding 1 van 1
    • Slide the orange latch sideways to eject the battery.
    • Remove the battery from the battery slot.
  3. Kodak EasyShare LS743 Microphone Replacement, Kodak EasyShare LS743 Camera Case Disassembly: stap 3, afbeelding 1 van 3 Kodak EasyShare LS743 Microphone Replacement, Kodak EasyShare LS743 Camera Case Disassembly: stap 3, afbeelding 2 van 3 Kodak EasyShare LS743 Microphone Replacement, Kodak EasyShare LS743 Camera Case Disassembly: stap 3, afbeelding 3 van 3
    • Using a Phillips #00 screwdriver, remove two 5.39 mm screws next to the battery slot.
    • Remove the metal piece holding down the lanyard, then remove the lanyard.
  4. Kodak EasyShare LS743 Microphone Replacement: stap 4, afbeelding 1 van 3 Kodak EasyShare LS743 Microphone Replacement: stap 4, afbeelding 2 van 3 Kodak EasyShare LS743 Microphone Replacement: stap 4, afbeelding 3 van 3
    • Using a Phillips #00 screwdriver, remove seven screws located on the outside case of the camera.
    • One 6.25 mm screw is located on the top right corner, right to the "OK" button.
    • Four 4.45 mm screws are on the bottom of the camera.
    • Two 2.95 mm screws are on the left side of the camera, above the USB port.
  5. Kodak EasyShare LS743 Microphone Replacement: stap 5, afbeelding 1 van 2 Kodak EasyShare LS743 Microphone Replacement: stap 5, afbeelding 2 van 2
    • Carefully remove the rear camera casing.
    • Carefully remove the front camera casing.
  6. Kodak EasyShare LS743 Microphone Replacement, Top and menu buttons: stap 6, afbeelding 1 van 2 Kodak EasyShare LS743 Microphone Replacement, Top and menu buttons: stap 6, afbeelding 2 van 2
    • Remove the top panel screw (1x 4.37mm).
  7. Kodak EasyShare LS743 Microphone Replacement: stap 7, afbeelding 1 van 2 Kodak EasyShare LS743 Microphone Replacement: stap 7, afbeelding 2 van 2
    • Remove the top panel.
  8. Kodak EasyShare LS743 Microphone Replacement: stap 8, afbeelding 1 van 2 Kodak EasyShare LS743 Microphone Replacement: stap 8, afbeelding 2 van 2
    • Remove the back panel screws (1x 3.33mm, and 1x 3.40mm).
  9. Kodak EasyShare LS743 Microphone Replacement: stap 9, afbeelding 1 van 3 Kodak EasyShare LS743 Microphone Replacement: stap 9, afbeelding 2 van 3 Kodak EasyShare LS743 Microphone Replacement: stap 9, afbeelding 3 van 3
    • Separate the inner casing from the tripod mount.
  10. Kodak EasyShare LS743 Microphone Replacement: stap 10, afbeelding 1 van 3 Kodak EasyShare LS743 Microphone Replacement: stap 10, afbeelding 2 van 3 Kodak EasyShare LS743 Microphone Replacement: stap 10, afbeelding 3 van 3
    • Gently pull the orange tab out of the circuit board.
  11. Kodak EasyShare LS743 Microphone Replacement: stap 11, afbeelding 1 van 2 Kodak EasyShare LS743 Microphone Replacement: stap 11, afbeelding 2 van 2
    • Carefully separate and flip over the LCD panel to expose the central circuit board.
  12. Kodak EasyShare LS743 Microphone Replacement: stap 12, afbeelding 1 van 1
    • Remove the (1x 3.33mm) screw from the menu button panel .
  13. Kodak EasyShare LS743 Microphone Replacement: stap 13, afbeelding 1 van 2 Kodak EasyShare LS743 Microphone Replacement: stap 13, afbeelding 2 van 2
    • Pull the second orange tab from the circuit board and remove the buttons.
  14. Kodak EasyShare LS743 Microphone Replacement, Removing LCD: stap 14, afbeelding 1 van 3 Kodak EasyShare LS743 Microphone Replacement, Removing LCD: stap 14, afbeelding 2 van 3 Kodak EasyShare LS743 Microphone Replacement, Removing LCD: stap 14, afbeelding 3 van 3
    • Flip up the LCD screen to reveal the two orange ribbon cables.
    • Disconnect the two ribbons cables from their sockets on the motherboard.
  15. Kodak EasyShare LS743 Microphone Replacement, Microphone: stap 15, afbeelding 1 van 1
    • Locate the microphone on top of the camera.
  16. Kodak EasyShare LS743 Microphone Replacement: stap 16, afbeelding 1 van 1
    • With an opening tool, pry the microphone away from the camera carefully.
  17. Kodak EasyShare LS743 Microphone Replacement: stap 17, afbeelding 1 van 1
    • Release the microphone from its pin and desolder.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Odessa
55 Reputatie
2 handleidingen geschreven
Cal Poly, Team 2-8, Johann Summer 2010 Lid van Cal Poly, Team 2-8, Johann Summer 2010
CPSU-JOHANN-R10S2G8
5 Leden
16 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 5
Altijd: 2,019
