Ga door naar hoofdinhoud
Kobo Mini Disassembly
Wat je nodig hebt
    1. Kobo Mini Disassembly, Kobo Mini Disassembly: stap 1, afbeelding 1 van 2 Kobo Mini Disassembly, Kobo Mini Disassembly: stap 1, afbeelding 2 van 2
      • Pull on the corner to remove the cover.
      Vraag FixBot
      Voeg opmerking toe
    2. Kobo Mini Disassembly: stap 2, afbeelding 1 van 1
      • Remove the six screws.
      • Remove the back of the device.
      Vraag FixBot
      Voeg opmerking toe
    3. Kobo Mini Disassembly: stap 3, afbeelding 1 van 1
      • Remove the four screws from the mother board.
      • Remove the screen connector and the battery connector.
      • Remove the micro SD card.
      • Remove the motherboard from the chassis.
      Vraag FixBot
      Voeg opmerking toe
    4. Kobo Mini Disassembly: stap 4, afbeelding 1 van 2 Kobo Mini Disassembly: stap 4, afbeelding 2 van 2
      • Remove the four screws from the screen frame.
      • Remove the screen
      Vraag FixBot
      Voeg opmerking toe
    5. Kobo Mini Disassembly: stap 5, afbeelding 1 van 1
      • And we finally finished.
      Vraag FixBot
      Voeg opmerking toe
Eindstreep
3 andere personen hebben deze handleiding voltooid.
Gabriel Bédard
360 Reputatie
1 Handleiding geschreven
9Gids Commentaar
Just a quick note, I noticed that the SD card in the teardown is a 4gb one. The Kobo Mini has only 2gb of storage. There's just under 2gb of unpartitioned space. You can use a partition manager to extend out the last partition to fill the card, and get close to 4gb of space.
There's a guide over on Mobile Read: https://www.mobileread.com/forums/showth...
Stephanie Raccoon - Antwoord Deel
Yes I think
Gabriel Bédard - Antwoord Deel
Thanks for the teardown! See https://www.mobileread.com/forums/showth... and https://wiki.mobileread.com/wiki/Kobo_Mi... for more disassembly advice and information about the components used.
I would be concerned about the reliability of the 4GB micro SD cards when extended to use the full unpartitioned space. While I could imagine a situation where 4GB cards were used due to unavailability of 2GB cards, there doesn’t seem to be a good reason to only format them to 2GB unless they were only guaranteed to reliably hold 2GB of data. In other words, I wonder if they were originally 4GB cards that failed some QA test and were only rated for use as 2GB capacity cards.
David Boddie - Antwoord Deel
How do you remove the battery connector? Simply pull? Remove the black little things on the sides in some way?
jasonhayden - Antwoord Deel
Yes you just need to pull it from the motherboard
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 26
Afgelopen 30 dagen: 131
Altijd: 7,677
