Inleiding
This guide will provide a detailed step-by-step instruction guide on how to remove the power cord from the KitchenAid Professional 600.
Wat je nodig hebt
Take out the screw which holds on the silver band using a Phillips #2 screwdriver.
Remove the silver band.
Locate the selector switch.
Remove the two Phillips #2 screws holding the selector switch in place.
Remove the two Phillips #2 screws holding the motor in place, located near the fan at the back of the motor.
Remove the Phillips #2 screw attaching the green grounding wire to the frame of the mixer.
Één andere persoon heeft deze handleiding voltooid.
