Ga door naar hoofdinhoud
KitchenAid KSM150PSER Speed Control Plate Replacement
Wat je nodig hebt
  1. KitchenAid KSM150PSER Speed Control Plate Replacement, Speed Control Plate: stap 1, afbeelding 1 van 2 KitchenAid KSM150PSER Speed Control Plate Replacement, Speed Control Plate: stap 1, afbeelding 2 van 2
    • Using a Phillips #2 screwdriver, remove the 10mm screw on the back cover by rotating it counterclockwise.
    • The back cover is now free. Remove it by pulling back and up on the cover.
    Vraag FixBot
    Voeg opmerking toe
  2. KitchenAid KSM150PSER Speed Control Plate Replacement: stap 2, afbeelding 1 van 3 KitchenAid KSM150PSER Speed Control Plate Replacement: stap 2, afbeelding 2 van 3 KitchenAid KSM150PSER Speed Control Plate Replacement: stap 2, afbeelding 3 van 3
    • Using a Phillips #2 screwdriver, remove the 5mm screws holding the trimband to the top housing by rotating them counterclockwise.
    • Pull the trimband off the housing by grabbing each side and pulling it off the front.
    Vraag FixBot
    Voeg opmerking toe
  3. KitchenAid KSM150PSER Speed Control Plate Replacement: stap 3, afbeelding 1 van 3 KitchenAid KSM150PSER Speed Control Plate Replacement: stap 3, afbeelding 2 van 3 KitchenAid KSM150PSER Speed Control Plate Replacement: stap 3, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    • Using a Phillips #2 screwdriver, remove the 12mm screw by holding the grounding wire in place and rotating it counterclockwise.
    • Using pliers or tweezers, remove the connectors attached to the speed control plate.
    Vraag FixBot
    Voeg opmerking toe
  4. KitchenAid KSM150PSER Speed Control Plate Replacement: stap 4, afbeelding 1 van 2 KitchenAid KSM150PSER Speed Control Plate Replacement: stap 4, afbeelding 2 van 2
    • Remove the seal from the back of the mixer. Then unhook the spring from the bottom of the speed control plate by using tweezers and pulling it back and out of the plate.
    • Take a rag or towel and hook the spring on the towel so that the hook doesn’t spring back inside the mixer.
    Vraag FixBot
    Voeg opmerking toe
  5. KitchenAid KSM150PSER Speed Control Plate Replacement: stap 5, afbeelding 1 van 2 KitchenAid KSM150PSER Speed Control Plate Replacement: stap 5, afbeelding 2 van 2
    • Using a Phillips #2 screwdriver, remove the two adjustment screws by rotating them counterclockwise.
    • Before beginning to remove the screws, use a ruler and measure how far the screws are in. These screws determine the speed of the mixer, and not screwing them back in to the same position will change the speed of the mixer.
    Vraag FixBot
    Voeg opmerking toe
  6. KitchenAid KSM150PSER Speed Control Plate Replacement: stap 6, afbeelding 1 van 1
    • The control plate can now be removed by pulling back on the plate.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
10 andere personen hebben deze handleiding voltooid.
Richa Gadgil
349 Reputatie
1 Handleiding geschreven
Cal Poly, Team S2-G5, Livingston Winter 2018 Lid van Cal Poly, Team S2-G5, Livingston Winter 2018
CPSU-LIVINGSTON-W18S2G5
4 Leden
16 handleidingen geschreven
1Gids Commentaar
Thanks for this, but a quick question, when the mixer is switched off, the metal bar on the back of the speed plate at the bottom, is that supposed to rest on the two prongs that stick out towards the bottom of the inside of the mixer? Thanks.
Mark R (dflipb) - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 10
Afgelopen 7 dagen: 48
Afgelopen 30 dagen: 171
Altijd: 24,663
