Ga door naar hoofdinhoud
KitchenAid KSB5CR Power Cable Replacement
Wat je nodig hebt
    1. KitchenAid KSB5CR Power Cable Replacement, Removing the Back Panel Part 1: stap 1, afbeelding 1 van 3 KitchenAid KSB5CR Power Cable Replacement, Removing the Back Panel Part 1: stap 1, afbeelding 2 van 3 KitchenAid KSB5CR Power Cable Replacement, Removing the Back Panel Part 1: stap 1, afbeelding 3 van 3
      • Remove the glass container and place the blender upside down on a solid surface.
      • Remove the four rubber feet using the needle nose pliers.
      • Remove the four #7.5 Phillips 25mm screws that were located underneath the rubber feet using the Phillips #2 screwdriver.
      Vraag FixBot
      Voeg opmerking toe
    2. KitchenAid KSB5CR Power Cable Replacement, Removing the Back Panel Part 2: stap 2, afbeelding 1 van 1
      • Lift the back panel up, sliding it along the power cord.
      Vraag FixBot
      Voeg opmerking toe
    1. KitchenAid KSB5CR Power Cable Replacement, Freeing the Power Cable: stap 3, afbeelding 1 van 1
      • Lift up on the power cable to pop it out of its holder.
      Vraag FixBot
      Voeg opmerking toe
    2. KitchenAid KSB5CR Power Cable Replacement, Detaching the White and Black Wires: stap 4, afbeelding 1 van 2 KitchenAid KSB5CR Power Cable Replacement, Detaching the White and Black Wires: stap 4, afbeelding 2 van 2
      • Be gentle with the knife or you will break the circuit board.
      • Slide the knife into the metal loop holding the insulation before the white copper wire, and wiggle it back and forth until it loosens.
      • Pull the wire out from the metal loop that you loosened.
      • Repeat this process with the black copper wire.
      Vraag FixBot
      Voeg opmerking toe
    3. KitchenAid KSB5CR Power Cable Replacement, Detatching the Green Wire: stap 5, afbeelding 1 van 2 KitchenAid KSB5CR Power Cable Replacement, Detatching the Green Wire: stap 5, afbeelding 2 van 2
      • Using the Phillips #2 screwdriver, remove the #8 Phillips 6mm screw to which the green wire is attached.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Cameron Geehr
745 Reputatie
6 handleidingen geschreven
Cal Poly, Team 12-5, Forte Fall 2014 Lid van Cal Poly, Team 12-5, Forte Fall 2014
CPSU-FORTE-F14S12G5
5 Leden
36 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 16
Altijd: 960
