Ga door naar hoofdinhoud
KitchenAid KHM512ER Power Cord Replacement
Wat je nodig hebt
    1. KitchenAid KHM512ER Power Cord Replacement, Power Cord: stap 1, afbeelding 1 van 2 KitchenAid KHM512ER Power Cord Replacement, Power Cord: stap 1, afbeelding 2 van 2
      • Insert the back of a plastic opening tool into one of the beater holes
      • Apply force to pull the circular plastic part off.
      • If necessary, use the other side of the plastic opening tool to pry the circular plastic part off.
      Vraag FixBot
      Voeg opmerking toe
    2. KitchenAid KHM512ER Power Cord Replacement: stap 2, afbeelding 1 van 3 KitchenAid KHM512ER Power Cord Replacement: stap 2, afbeelding 2 van 3 KitchenAid KHM512ER Power Cord Replacement: stap 2, afbeelding 3 van 3
      • Use a plastic opening tool to remove the speed knob.
      • Pop up the panel with a plastic opening tool.
      • Use a plastic opening tool to pry the white plastic switch assembly out.
      Vraag FixBot
      Voeg opmerking toe
    3. KitchenAid KHM512ER Power Cord Replacement: stap 3, afbeelding 1 van 2 KitchenAid KHM512ER Power Cord Replacement: stap 3, afbeelding 2 van 2
      • Use a Phillips 2 screwdriver to remove the two 20.0mm screws that hold the bottom plastic piece.
      • Your screwdriver may not be long or narrow enough to reach the screws in these holes. If that's the case, use another screwdriver.
      • Remove the bottom plastic piece using a plastic opening tool.
      Vraag FixBot
      Voeg opmerking toe
    4. KitchenAid KHM512ER Power Cord Replacement: stap 4, afbeelding 1 van 3 KitchenAid KHM512ER Power Cord Replacement: stap 4, afbeelding 2 van 3 KitchenAid KHM512ER Power Cord Replacement: stap 4, afbeelding 3 van 3
      • Using a Phillips 2 screwdriver, remove the three 20.0mm screws holding the motor assembly in place.
      • Use your hands to remove the motor assembly and circuit board.
      Vraag FixBot
      Voeg opmerking toe
    5. KitchenAid KHM512ER Power Cord Replacement: stap 5, afbeelding 1 van 3 KitchenAid KHM512ER Power Cord Replacement: stap 5, afbeelding 2 van 3 KitchenAid KHM512ER Power Cord Replacement: stap 5, afbeelding 3 van 3
      • Firmly grip the circuit board, and using pliers, remove the black and white power cord connectors from the circuit board.
      • Some force may be required. Be careful not to cut yourself on any electrical components.
      Vraag FixBot
      Voeg opmerking toe
    6. KitchenAid KHM512ER Power Cord Replacement: stap 6, afbeelding 1 van 3 KitchenAid KHM512ER Power Cord Replacement: stap 6, afbeelding 2 van 3 KitchenAid KHM512ER Power Cord Replacement: stap 6, afbeelding 3 van 3
      • Using a plastic opening tool, remove the white plastic clip on the inside of the bottom plastic piece.
      • Once it's loose, remove it with your fingers.
      • Pull the power cord through the hole.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Brad Daniels
636 Reputatie
3 handleidingen geschreven
USF Tampa, Team 2-3, Sullivan Spring 2016 Lid van USF Tampa, Team 2-3, Sullivan Spring 2016
USFT-SULLIVAN-S16S2G3
3 Leden
9 handleidingen geschreven
1Gids Commentaar
where to find this cord?
Markian G.G. - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 47
Altijd: 4,495
