Ga door naar hoofdinhoud
KitchenAid KHM512ER Eject Button Spring Replacement
Wat je nodig hebt
    1. KitchenAid KHM512ER Eject Button Spring Replacement, Eject Button Spring: stap 1, afbeelding 1 van 2 KitchenAid KHM512ER Eject Button Spring Replacement, Eject Button Spring: stap 1, afbeelding 2 van 2
      • Insert the back of a plastic opening tool into one of the beater holes.
      • Apply force to pull the circular plastic part off.
      • If necessary, use the other side of the plastic opening tool to pry the circular plastic part off.
      Vraag FixBot
      Voeg opmerking toe
    2. KitchenAid KHM512ER Eject Button Spring Replacement: stap 2, afbeelding 1 van 3 KitchenAid KHM512ER Eject Button Spring Replacement: stap 2, afbeelding 2 van 3 KitchenAid KHM512ER Eject Button Spring Replacement: stap 2, afbeelding 3 van 3
      • Use a plastic opening tool to remove the speed knob.
      • Use a plastic opening tool to remove the long plastic piece
      • Use a plastic opening tool to remove the speed switch.
      Vraag FixBot
      Voeg opmerking toe
    3. KitchenAid KHM512ER Eject Button Spring Replacement: stap 3, afbeelding 1 van 2 KitchenAid KHM512ER Eject Button Spring Replacement: stap 3, afbeelding 2 van 2
      • Use a Phillips 2 screwdriver to remove the two 20.0mm screws holding the bottom plastic piece on.
      • Your screwdriver may not be long or narrow enough to reach the screws in these holes. If that's the case, use another screwdriver.
      • Remove the bottom plastic piece using a plastic opening tool.
      Vraag FixBot
      Voeg opmerking toe
    4. KitchenAid KHM512ER Eject Button Spring Replacement: stap 4, afbeelding 1 van 3 KitchenAid KHM512ER Eject Button Spring Replacement: stap 4, afbeelding 2 van 3 KitchenAid KHM512ER Eject Button Spring Replacement: stap 4, afbeelding 3 van 3
      • Using a Phillips 2 screwdriver, remove the three 20.0mm screws holding the motor assembly in place.
      • Use your hands to remove the motor assembly.
      • Use your hands to hold the eject button from one side while using the other hand to remove the circuit board.
      Vraag FixBot
      Voeg opmerking toe
    5. KitchenAid KHM512ER Eject Button Spring Replacement: stap 5, afbeelding 1 van 2 KitchenAid KHM512ER Eject Button Spring Replacement: stap 5, afbeelding 2 van 2
      • Remove the eject button by pulling it from the inside of the mixer.
      • Hold the eject button firmly while pulling out the spring.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Yuriy Zaynulin
191 Reputatie
1 Handleiding geschreven
USF Tampa, Team 2-3, Sullivan Spring 2016 Lid van USF Tampa, Team 2-3, Sullivan Spring 2016
USFT-SULLIVAN-S16S2G3
3 Leden
9 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 35
Altijd: 2,097
