Ga door naar hoofdinhoud
Kitchen Faucet Replacement
Wat je nodig hebt
  1. Kitchen Faucet Replacement, Kitchen Faucet: stap 1, afbeelding 1 van 3 Kitchen Faucet Replacement, Kitchen Faucet: stap 1, afbeelding 2 van 3 Kitchen Faucet Replacement, Kitchen Faucet: stap 1, afbeelding 3 van 3
    • Rotate the hot and cold water valve knobs under the sink clockwise to turn off the water.
    • Turn on the faucet to relieve the pressure and any remaining water for about one minute.
  2. Kitchen Faucet Replacement: stap 2, afbeelding 1 van 3 Kitchen Faucet Replacement: stap 2, afbeelding 2 van 3 Kitchen Faucet Replacement: stap 2, afbeelding 3 van 3
    • Place a bucket underneath the valves to catch dripping water.
    • Turn the hot and cold supply line nuts clockwise until the water supply lines come out.
    • For a pull-down faucet, disconnect the spray hose from both the spray head and the main body.
  3. Kitchen Faucet Replacement: stap 3, afbeelding 1 van 3 Kitchen Faucet Replacement: stap 3, afbeelding 2 van 3 Kitchen Faucet Replacement: stap 3, afbeelding 3 van 3
    • Loosen and remove the nuts underneath the sink by using an adjustable wrench.
    • Remove the mounting bracket.
  4. Kitchen Faucet Replacement: stap 4, afbeelding 1 van 2 Kitchen Faucet Replacement: stap 4, afbeelding 2 van 2
    • Use your hands to pull the faucet out of the sink.
    • Clean away any grime or sealant with a cleaning spray and towel.
  5. Kitchen Faucet Replacement: stap 5, afbeelding 1 van 3 Kitchen Faucet Replacement: stap 5, afbeelding 2 van 3 Kitchen Faucet Replacement: stap 5, afbeelding 3 van 3
    • Place the trim ring on the faucet hole.
    • Feed the faucet into the faucet hole and position it.
    • Different faucets install differently, so be sure to read and follow the instructions for your faucet.
  6. Kitchen Faucet Replacement: stap 6, afbeelding 1 van 2 Kitchen Faucet Replacement: stap 6, afbeelding 2 van 2
    • Underneath the sink, put the mounting bracket back in place, and turn the nuts to tighten them.
  7. Kitchen Faucet Replacement: stap 7, afbeelding 1 van 3 Kitchen Faucet Replacement: stap 7, afbeelding 2 van 3 Kitchen Faucet Replacement: stap 7, afbeelding 3 van 3
    • Hook the water supply lines up by turning the hot and cold supply line nuts counter clockwise.
    • For pull-down faucets, attach the weight kit on the spray hose and connect it to both the spray head and the pull-out hose.
  8. Kitchen Faucet Replacement: stap 8, afbeelding 1 van 3 Kitchen Faucet Replacement: stap 8, afbeelding 2 van 3 Kitchen Faucet Replacement: stap 8, afbeelding 3 van 3
    • Rotate the hot and cold water valve knobs counter clockwise to turn on the water under the sink.
    • Once it is all done, check if there are any leaks.
Eindstreep
Bongsu Kim
184 Reputatie
1 Handleiding geschreven
1Gids Commentaar
Great guide on kitchen faucet replacement! I was able to follow the steps and successfully replace my old faucet with a new one. The pictures and detailed instructions made the process much easier. Thank you for sharing this useful information!
Scott Robillard - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 5
Afgelopen 7 dagen: 21
Afgelopen 30 dagen: 82
Altijd: 1,359
