Ga door naar hoofdinhoud
How to Clean a Kitchen Aerator
Wat je nodig hebt
  1. How to Clean a Kitchen Aerator, How to Clean a Kitchen Aerator: stap 1, afbeelding 1 van 2 How to Clean a Kitchen Aerator, How to Clean a Kitchen Aerator: stap 1, afbeelding 2 van 2
    • Shut off valves that are located under the sink and position faucet in the center to drain remaining water.
  2. How to Clean a Kitchen Aerator: stap 2, afbeelding 1 van 1
    • Avoid dropping small parts down the sink by covering the surface of the holes.
  3. How to Clean a Kitchen Aerator: stap 3, afbeelding 1 van 1
    • Unscrew and remove aerator with a wrench.
  4. How to Clean a Kitchen Aerator: stap 4, afbeelding 1 van 1
    • Clean aerator by soaking it in white vinegar overnight in a bowl or cup.
  5. How to Clean a Kitchen Aerator: stap 5, afbeelding 1 van 1
    • Dry off aerator with a towel.
  6. How to Clean a Kitchen Aerator: stap 6, afbeelding 1 van 1
    • Use a wrench to screw back on the aerator to the faucet.
  7. How to Clean a Kitchen Aerator: stap 7, afbeelding 1 van 1
    • Slowly turn back on water valves to check for improves water pressure.
    • Make sure sink is cleared and components of faucet that were removed are sealed tight.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Amber Cuddon
181 Reputatie
1 Handleiding geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 5
Afgelopen 7 dagen: 24
Afgelopen 30 dagen: 98
Altijd: 1,708
