Inleiding
Vibration is a useful tool to ensure the user that a device is responding to the press of a button. This guide shows how to replace the vibrator in a Kindle Voyage should the device fail to vibrate properly.
Wat je nodig hebt
Insert a plastic opening tool between the plastic panel shown on the device.
Use the tool to pry the plastic away from the device.
Gereedschap gebruikt in deze stap:Tweezers$4.99
Use tweezers to pinch in the sides of the vibrator cable and slide it out of its housing.
1Gids Commentaar
OK, the procedure seems straightforward enough, but you say “no parts required” when you actually *do* need to buy the replacement parts for the pieces that are no longer functioning. Where can you buy these parts?
