Ga door naar hoofdinhoud
Kindle Paperwhite 3rd Generation Motherboard Replacement
Wat je nodig hebt
    1. Kindle Paperwhite 3rd Generation Motherboard Replacement, Battery: stap 1, afbeelding 1 van 3 Kindle Paperwhite 3rd Generation Motherboard Replacement, Battery: stap 1, afbeelding 2 van 3 Kindle Paperwhite 3rd Generation Motherboard Replacement, Battery: stap 1, afbeelding 3 van 3
      • Ensure that the device is turned off before beginning.
      • Gently pry the bezel off the screen using a plastic opening tool. Start at the corners and slide around the edges until you return to your starting point.
      • Be careful if using the metal spudger, as it can scratch the surface of the Kindle.
      Vraag FixBot
      Voeg opmerking toe
    2. Kindle Paperwhite 3rd Generation Motherboard Replacement, Using caution: stap 2, afbeelding 1 van 3 Kindle Paperwhite 3rd Generation Motherboard Replacement, Using caution: stap 2, afbeelding 2 van 3 Kindle Paperwhite 3rd Generation Motherboard Replacement, Using caution: stap 2, afbeelding 3 van 3
      • Use extreme caution when prying up the bezel. Be careful not to allow your pry tool to fall underneath the display. Look under the cover as you work, separating the display from the adhesive of the bezel.
      • You want to make sure your separator goes through both sides of the bezel over top of the display.
      • The second photo is the layer you want your tool to pass through safely.
      • The third photo is an example of what can go wrong. If this happens your digitizer layer will misread touches and the display is permanently damaged.
      Vraag FixBot
      Voeg opmerking toe
    3. Kindle Paperwhite 3rd Generation Motherboard Replacement: stap 3, afbeelding 1 van 2 Kindle Paperwhite 3rd Generation Motherboard Replacement: stap 3, afbeelding 2 van 2
      • Unscrew the eleven 3.2 mm Phillips #000 screws surrounding the frame.
      Vraag FixBot
      Voeg opmerking toe
    4. Kindle Paperwhite 3rd Generation Motherboard Replacement: stap 4, afbeelding 1 van 1
      • Gently lift the mid-frame out of the case with your hands.
      • Lift the side opposite of the power button out first.
      Vraag FixBot
      Voeg opmerking toe
    5. Kindle Paperwhite 3rd Generation Motherboard Replacement: stap 5, afbeelding 1 van 2 Kindle Paperwhite 3rd Generation Motherboard Replacement: stap 5, afbeelding 2 van 2
      • Unscrew the three 3.0 mm Phillips #000 screws that are securing the battery.
      Vraag FixBot
      Voeg opmerking toe
    6. Kindle Paperwhite 3rd Generation Motherboard Replacement: stap 6, afbeelding 1 van 1
      • Gently lift the battery from the frame.
      Vraag FixBot
      Voeg opmerking toe
    1. Kindle Paperwhite 3rd Generation Motherboard Replacement, Motherboard: stap 7, afbeelding 1 van 1
      • Flip the black latch with a plastic opening tool, and then gently pull back the orange ribbon cable.
      Vraag FixBot
      Voeg opmerking toe
    2. Kindle Paperwhite 3rd Generation Motherboard Replacement: stap 8, afbeelding 1 van 1
      Gereedschap gebruikt in deze stap:
      • Flip the tiny off-white latch with angled precision tweezers toward the direction of the battery.
      • Gently peel back the orange ribbon cable.
      Vraag FixBot
      Voeg opmerking toe
    3. Kindle Paperwhite 3rd Generation Motherboard Replacement: stap 9, afbeelding 1 van 2 Kindle Paperwhite 3rd Generation Motherboard Replacement: stap 9, afbeelding 2 van 2
      • Peel back the orange ribbon cable near the battery.
      • Flip the tiny black latch with angled precision tweezers toward the closest edge of the device.
      Vraag FixBot
      Voeg opmerking toe
    4. Kindle Paperwhite 3rd Generation Motherboard Replacement: stap 10, afbeelding 1 van 1
      • Peel back the white connector with your fingers.
      Vraag FixBot
      Voeg opmerking toe
    5. Kindle Paperwhite 3rd Generation Motherboard Replacement: stap 11, afbeelding 1 van 2 Kindle Paperwhite 3rd Generation Motherboard Replacement: stap 11, afbeelding 2 van 2
      • Unscrew the six 3.0 mm Phillips #000 screws surrounding the motherboard.
      • Unscrew the one 2.5 mm Phillips #000 screw.
      • There is a little metal plate underneath the 2.5 mm screw and washers under four of the 3.0 mm screws.
      Vraag FixBot
      Voeg opmerking toe
    6. Kindle Paperwhite 3rd Generation Motherboard Replacement: stap 12, afbeelding 1 van 1
      • Use a plastic opening tool to lift the motherboard upwards from the frame.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
13 andere personen hebben deze handleiding voltooid.
Micah Smart
3.428 Reputatie
3 handleidingen geschreven
USF Tampa, Team 14-3, Lacy Spring 2016 Lid van USF Tampa, Team 14-3, Lacy Spring 2016
USFT-LACY-S16S14G3
4 Leden
14 handleidingen geschreven
6Gids Commentaar
how do I fix my loose charging port?
angusc - Antwoord Deel
how do i fix my loose charging port connection
Where can I buy a kindle paper white, new mother board?
Lorraine - Antwoord Deel
Tip, heat the front bezel to soften the glue.
KAASKOP3000 - Antwoord Deel
I totally know how to fix my kindle but I don’t know where to get the part. I broke the tip to the ribbon cable for the only %#*@ button on the device. do they sell those here?
Corry Newton - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 57
Afgelopen 30 dagen: 161
Altijd: 15,449
