Ga door naar hoofdinhoud
Kindle Paperwhite 3rd Generation Battery Replacement
Wat je nodig hebt
  1. Kindle Paperwhite 3rd Generation Battery Replacement, Battery: stap 1, afbeelding 1 van 3 Kindle Paperwhite 3rd Generation Battery Replacement, Battery: stap 1, afbeelding 2 van 3 Kindle Paperwhite 3rd Generation Battery Replacement, Battery: stap 1, afbeelding 3 van 3
    • Ensure that the device is turned off before beginning.
    • Gently pry the bezel off the screen using a plastic opening tool. Start at the corners and slide around the edges until you return to your starting point.
    • Be careful if using the metal spudger, as it can scratch the surface of the Kindle.
    Be very careful along the lower left side, where the cable to the touchscreen can be easily cut with a plastic spudger.
    John Kenny - Antwoord
    Be careful at the top of the 3G version. The wifi and cell antennas are located along here.
    James Sullivan - Antwoord
    I can’t get my spudger in to start lifting. Any advice?
    Davey - Antwoord
    it takes a bit of force to first insert the spudger into the crack
    jookieapc -
    Be careful inserting the spudger too quickly. The glue holding the screen pulled loose in two spots along the side before the bezel did and there are lines along the border of my screen now.
    Nick - Antwoord
    I made my own version of Nick’s error: I inserted a pick too far under the bezel, and very slightly separated the screen, leaving a small shadow in a corner. Easy does it!
    Other than that, battery replacement was super-easy and successful.
    Brad Compton - Antwoord
    I couldn't get a purchase from the outside, so started from the inside of the bezel. It was secured with double sided tape. Might have been better to apply some heat before prying.
    David Glover - Antwoord
    Used the guide to replace the battery. Could not get enough separation using the blue spudger. Used the metal spidger to get things started then switched to the blue picks. Afterthought, Warming the bezel would have helped.
    Jeffry Long - Antwoord
  2. Kindle Paperwhite 3rd Generation Battery Replacement, Using caution: stap 2, afbeelding 1 van 3 Kindle Paperwhite 3rd Generation Battery Replacement, Using caution: stap 2, afbeelding 2 van 3 Kindle Paperwhite 3rd Generation Battery Replacement, Using caution: stap 2, afbeelding 3 van 3
    • Use extreme caution when prying up the bezel. Be careful not to allow your pry tool to fall underneath the display. Look under the cover as you work, separating the display from the adhesive of the bezel.
    • You want to make sure your separator goes through both sides of the bezel over top of the display.
    • The second photo is the layer you want your tool to pass through safely.
    • The third photo is an example of what can go wrong. If this happens your digitizer layer will misread touches and the display is permanently damaged.
    Scheiß Anleitung. Das Glas muss man nicht lösen um den Akku zu wechseln.
    Christoph B. - Antwoord
  3. Kindle Paperwhite 3rd Generation Battery Replacement: stap 3, afbeelding 1 van 2 Kindle Paperwhite 3rd Generation Battery Replacement: stap 3, afbeelding 2 van 2
    • Unscrew the eleven 3.2 mm Phillips #000 screws surrounding the frame.
    I have a 3rd Gen Paperwhite and there are only 10 screws. 5 along each side
    jookieapc - Antwoord
    Mine had 11, as per the instructions, one of which was hidden under tape. I cut an opening in it.
    Should have read Glover's comment.
    Looked for the middle screw but the black tape covered all appearances of it. Lifting the mid-frame out of the case snapped the mount. However, there was plenty of support with the ten screws and no lasting damage to the reader.
  4. Kindle Paperwhite 3rd Generation Battery Replacement: stap 4, afbeelding 1 van 1
    • Gently lift the mid-frame out of the case with your hands.
    • Lift the side opposite of the power button out first.
    I had trouble removing it. It was stuck and I managed only to free it with force. Now I have to fix the button..
    LGenie - Antwoord
    I forgot to remove the 11th screw in the center top which was covered up by a black adhesive strip, which prevented me from removing the frame. I ended up breaking the case because I applied too much force.
    Simon - Antwoord
  5. Kindle Paperwhite 3rd Generation Battery Replacement: stap 5, afbeelding 1 van 2 Kindle Paperwhite 3rd Generation Battery Replacement: stap 5, afbeelding 2 van 2
    • Unscrew the three 3.0 mm Phillips #000 screws that are securing the battery.
  6. Kindle Paperwhite 3rd Generation Battery Replacement: stap 6, afbeelding 1 van 1
    • Gently lift the battery from the frame.
    We had a Kindle that unfortunately took a dunk in (clean) water. It was then inoperative. I followed this guide, and took the battery out, let everything dry for a few days, then replaced the battery. Now it works fine! Thanks!
    Frank Demarest - Antwoord
Conclusie
83 andere personen hebben deze handleiding voltooid.
Micah Smart
3.336 Reputatie
3 handleidingen geschreven
USF Tampa, Team 14-3, Lacy Spring 2016 Lid van USF Tampa, Team 14-3, Lacy Spring 2016
USFT-LACY-S16S14G3
4 Leden
10 handleidingen geschreven
22Gids Commentaar
Same for 5th Generation ??
PAUL FRIEND - Antwoord
where can i buy a new battery ?
david horn - Antwoord
you need a taobao.
lol
kassadin -
They are sold on aliexpress and ebay but the price of battery and postage is not that different from the price of a second hand 3ed Gen Kindle. But then the second hand Kindle will probably need a new battery too so, I am going to get a battery from ebay.
Timothy Takemoto -
where can I buy a replacement battery?
boelens - Antwoord
If the charging light does not turn on (at all, no colour) - does it make sense for me to try a new battery?
Artūrs Lataks - Antwoord
Yes unless you want to buy a new Kindle. Batteries (MC-354775-05) run under 20 from various sites.
DDD -
I used this guide to replace the battery in my Kindle which I bought in 2016 - the battery was down to only holding charge for a few hours. My kindle usage is heavy though - especially while sitting out 12 weeks of redundancy with nothing to do - it was a real sanity saver.
I bought the replacement marked as 58-000049 compatible - which it was
Thank you
jacqui_scarff - Antwoord
How can I tell which generation my Kindle Paperwhite is?
pbr - Antwoord
when removing the frame, the edges of the display have unfortunately lifted off a bit, respectively there are now some slight scratches at the corners of the display, as if the foil was off there.
Is there anything I can do about it? Thanks in advance
bastimm - Antwoord
Thank you for this! Just did it myself. The only thing I would add to this guide is that you may need to replace the adhesive for the bezel — the corner that I initially peeled off had some trouble staying down after I replaced it.
Matthew Fox - Antwoord
Worked almost fine for me! Found replacement battery on ebay with original model number.
The only point I somehow struggled with is the fact that there is no option to shut down the paperwhite. The only options my device provide are reboot and display off (and cancel of course). However, I selected reboot, lowered 2 screws from the battery and before booting up again I removed the last screw and replaced the battery.
Groej Htro - Antwoord
This worked fine for me battery is great only problem is that the backlight (actually front light at bottom of display) no longer work!1
David Binder - Antwoord
That worked well. Thank you.
judithmatz - Antwoord
Go easier on the spudger than I did. Go in too far, and you can separate the screen, causing a permanent issue. Any tape from under the bezel that tears needs to be replaced as best you can as its absence will cause light to show through the bezel in that spot when you reassemble anything.
shf781 - Antwoord
Available for Kindle 8th generation.
cssuntherrao - Antwoord
Thank you, that middle screw at the very top was hidden behind the adhesive on mine so I would have missed it if it wasn't for the guide. Also wanted to mention that there is a couple of clips holding the mid frame so I had to gently pry it away with my plastic opening tool. Other than that, no issues!
Chris Horry - Antwoord
Hi when I attempted to remove the bezel, it looks like the top layer of the screen came with it there are weird wavy lines on the screen. It appears the top layer of the screen separated and now won't meld properly with the underlayer. has anyone had this problem and can it be fixed without replacing the screen?
Lauren Carroll - Antwoord
更换完后需要恢复出厂设置吗?会不会存在系统无法识别新电池容量的情况?
Jobs Tri - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 39
Afgelopen 7 dagen: 312
Afgelopen 30 dagen: 1,332
Altijd: 86,242
