Ga door naar hoofdinhoud
Kindle Paperwhite 2nd Generation Screen Replacement
Wat je nodig hebt
  1. Kindle Paperwhite 2nd Generation Screen Replacement, Screen: stap 1, afbeelding 1 van 1
    • Insert plastic opening tool into the corners of the Paperwhite and slide around the edge perimeter to remove bezel.
    • Be sure to begin prying along the edges, these are the optimal points for removing the bezel.
    Vraag FixBot
    Voeg opmerking toe
  2. Kindle Paperwhite 2nd Generation Screen Replacement: stap 2, afbeelding 1 van 2 Kindle Paperwhite 2nd Generation Screen Replacement: stap 2, afbeelding 2 van 2
    • Remove the eleven 3.2 mm Phillips 000 screws from corners of mid-frame and from behind the black strip as shown.
    • Do not forget the screw in the middle of the black adhesive strip.
    Vraag FixBot
    Voeg opmerking toe
  3. Kindle Paperwhite 2nd Generation Screen Replacement: stap 3, afbeelding 1 van 1
    • Carefully lift and remove the mid-frame.
    Vraag FixBot
    Voeg opmerking toe
  4. Kindle Paperwhite 2nd Generation Screen Replacement: stap 4, afbeelding 1 van 1
    • The screen itself is glued to the mid-frame. If your replacement screen does not include the mid-frame, heat the screen with an iOpener and gently pry it from the mid-frame with a blue plastic opening tool.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
8 andere personen hebben deze handleiding voltooid.
Tyler Davis
2.007 Reputatie
5 handleidingen geschreven
USF Tampa, Team 11-2, Blackwell Fall 2016 Lid van USF Tampa, Team 11-2, Blackwell Fall 2016
USFT-BLACKWELL-F16S11G2
4 Leden
20 handleidingen geschreven
3Gids Commentaar
My opening tool is orange. Will this still work for me?
FoxRunTime - Antwoord Deel
I’m hoping to replace my screen with this part:
Kindle Paperwhite (2nd Gen) Display
Does this part include the mid-frame? I would like to avoid using the iOpener if possible.
Thank you!
Liam Cahill - Antwoord Deel
Did this work Liam?
Ben Lowdon - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 31
Afgelopen 30 dagen: 112
Altijd: 15,477
