Ga door naar hoofdinhoud
Kindle Paperwhite 1st Generation Battery Replacement
Wat je nodig hebt
  1. Kindle Paperwhite 1st Generation Battery Replacement, Case: stap 1, afbeelding 1 van 2 Kindle Paperwhite 1st Generation Battery Replacement, Case: stap 1, afbeelding 2 van 2
    • Using a spudger or plastic opening tool, gently pry the bezel from the screen. It is easier to start in the corners and work your way around the bezel.
    • Do not insert the spudger too far under the bezel; it could easily damage the screen.
    Vraag FixBot
    Voeg opmerking toe
  2. Kindle Paperwhite 1st Generation Battery Replacement: stap 2, afbeelding 1 van 3 Kindle Paperwhite 1st Generation Battery Replacement: stap 2, afbeelding 2 van 3 Kindle Paperwhite 1st Generation Battery Replacement: stap 2, afbeelding 3 van 3
    • Remove the eleven 3.0 mm Phillips screws surrounding the midframe.
    • At the top of the display, a strip of black tape covers one screw.
    Vraag FixBot
    Voeg opmerking toe
  3. Kindle Paperwhite 1st Generation Battery Replacement: stap 3, afbeelding 1 van 1
    • Lift the midframe out of the case.
    • If the midframe is stuck, slide it to the left first, and then lift it out.
    Vraag FixBot
    Voeg opmerking toe
  4. Kindle Paperwhite 1st Generation Battery Replacement, Battery: stap 4, afbeelding 1 van 2 Kindle Paperwhite 1st Generation Battery Replacement, Battery: stap 4, afbeelding 2 van 2
    • Turn over the midframe to locate the battery.
    • Remove the three Phillips 3.0 mm screws securing the battery to the midframe.
    Vraag FixBot
    Voeg opmerking toe
  5. Kindle Paperwhite 1st Generation Battery Replacement: stap 5, afbeelding 1 van 1
    • Gently lift the battery from the bottom, and slide it out of the midframe.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
70 andere personen hebben deze handleiding voltooid.
Isabelle Burgess
1.657 Reputatie
2 handleidingen geschreven
Cal Poly, Team 3-33, Amido Winter 2013 Lid van Cal Poly, Team 3-33, Amido Winter 2013
CPSU-AMIDO-W13S3G33
4 Leden
19 handleidingen geschreven
14Gids Commentaar
You may not need a new battery. I had the issue of the paperwhite re-indexing ALL of my content and getting snagged on a corrupted book toward the end of the process. This looks for all the world like the battery is dying.
Backup your kindle devices folder to a computer.
Delete everything but the book you are reading.
Delete the hidden indexes in the system folder.
Restart the kindle.
Now it should charge to 100% - and last weeks instead of hours.
(search for kindle paperwhite indexing battery re-indexing)
cimac tiga - Antwoord Deel
If you have a corrupted book how do you tell which one it is?
Bonnie Ferguson - Antwoord Deel
The spudger was no help what so ever as it was too thick to get between the edge. I finally had to use a exacto knife. And the #2 screwdriver they recommended was laughably large! I ended up using a screwdriver I got with a kit to tighten your glasses. On the battery (which iFixit doesn't sell but recommended from another seller) the last two digits were different (03 rather than 05) and it didn't work. I don't know if that's why, or if something else is wrong. The only thing that was useful was the video - at least I knew what to do and the order to do it. Too bad none of it worked. Guess I'm getting a new Paperwhite Kindle!
pjparke - Antwoord Deel
The battery on my Kindle Paperwhite 1st Gen died earlier this month. I ordered a replacement battery online, opened my Paperwhite using the instructions on this page, replaced the battery and yeehaa, it works again. Thank you!!!!
Paul Magis - Antwoord Deel
My Kindle Paperwhite (first generation) only has 10 screws rather than 11 as described, i.e. the one in the top middle is missing from the description. So before digging for that extra screw you might want to check whether the midframe lifts out of the case already with the 10 easily accessible screws removed.
I had some trouble first with prying off the bezel using different spudger tools. The Jimmy finally did the trick for me, since it is thin enough to get into the edge around the screen and also flexible enough to cut into the adhesive.
markus - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 12
Afgelopen 7 dagen: 87
Afgelopen 30 dagen: 391
Altijd: 150,796
