Inleiding
The Kindle Paperwhite 12th gen screen is a complex part with everything altogether including the hardware casing for the motherboard and battery, the ribbon cables to connect them to the Kindle, and the screen itself. It also houses the systems light and touchscreen system. Replacement of the screen should be done as a last effort, as the price of the screen part is a considerable majority of the price of the main product, but it can solve any issues with burn-in or ghosting, as well as touch screen sensitivity issues and internal lighting issues. The replacement will consist of taking out every piece of hardware and reinstalling it into the new housing,
Wat je nodig hebt
Use an opening tool or opening picks and insert the tip between the back case and screen.
Slide the opening tool around the edge of the tablet to release the clips holding them together and avoid damaging the connectors.
Place a spudger or an opening tool under the connector's edge and pry straight up to disconnect it.
Place a spudger or an opening tool under the press connector edge and pry straight up to disconnect it.
Één andere persoon heeft deze handleiding voltooid.
