Ga door naar hoofdinhoud
Kindle Fire HD 6 Battery Replacement
Wat je nodig hebt
    1. Kindle Fire HD 6 Battery Replacement, Back Panel: stap 1, afbeelding 1 van 1
      • Place the device face down on a clean cloth or another smooth surface.
      • In the following steps, you will need to apply some force to your device. If your device is on a rough surface, you may scratch the screen.
      • Insert the plastic opening tool between the device’s front and back panels. You might need to wiggle the tool up and down to wedge it in the gap.
      • Maneuver the tool around the device until the back unclips from the front panel.
      Vraag FixBot
      Voeg opmerking toe
    2. Kindle Fire HD 6 Battery Replacement: stap 2, afbeelding 1 van 2 Kindle Fire HD 6 Battery Replacement: stap 2, afbeelding 2 van 2
      • Carefully separate the back panel from the rest of the device internals.
      Vraag FixBot
      Voeg opmerking toe
    1. Kindle Fire HD 6 Battery Replacement, Battery: stap 3, afbeelding 1 van 1
      Gereedschap gebruikt in deze stap:
      iOpener
      $14.95
      • Gently pry the battery free from the adhesive holding it in place.
      • Take care not to pierce or rupture the battery, which can release dangerous chemicals.
      • If you're having trouble working the battery free, warm it up with an iOpener or hair dryer to soften the adhesive, and then slide a credit card behind the battery to break up the adhesive.
      • Be careful not to yank the battery out—you'll need to disconnect a connector before removing the battery completely.
      Vraag FixBot
      Voeg opmerking toe
    2. Kindle Fire HD 6 Battery Replacement: stap 4, afbeelding 1 van 2 Kindle Fire HD 6 Battery Replacement: stap 4, afbeelding 2 van 2
      • Remove the multi-colored connector that joins the battery and the motherboard by pulling it straight up.
      • Remove the battery.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
18 andere personen hebben deze handleiding voltooid.
Cassandra Beck
885 Reputatie
5 handleidingen geschreven
Cal Poly, Team 70-4, Forte Winter 2015 Lid van Cal Poly, Team 70-4, Forte Winter 2015
CPSU-FORTE-W15S70G4
4 Leden
12 handleidingen geschreven
2Gids Commentaar
Thank you it worked for me.
A bit nervous breaking it down, once I got the back plate off it was very simple, unplugged the battery, reconnected put it back together fired it up , great advice.
Thanks again
Regards
Terry
terry pils - Antwoord Deel
The battery removal step did not sufficiently warn about how hard the adhesive used for the battery was, and using the spudger ended up piercing the battery when I tried to pry the battery off.
Sean Collins - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 20
Afgelopen 30 dagen: 82
Altijd: 9,608
