Ga door naar hoofdinhoud
Kindle Fire Front Glass Panel Replacement
Wat je nodig hebt
  1. Kindle Fire Front Glass Panel Replacement, Back Case: stap 1, afbeelding 1 van 3 Kindle Fire Front Glass Panel Replacement, Back Case: stap 1, afbeelding 2 van 3 Kindle Fire Front Glass Panel Replacement, Back Case: stap 1, afbeelding 3 van 3
    • Wedge a plastic opening tool into the lower right corner of the Kindle Fire.
    • Pry the case apart and run the plastic opening tool along the perimeter of the Kindle Fire to release the clips securing the case halves to each other.
    • If you are having extreme difficulty inserting the plastic opening tool, carefully use a metal spudger to undo the first clip, then switch back to the opening tool to avoid scratching your case.
    • It is helpful to pry the bottom of the Kindle Fire away (and out from the side) from the top part. Exerting too much force attempting to split the two without pulling away can cause the tabs on the inside to crack.
    Vraag FixBot
    Voeg opmerking toe
  2. Kindle Fire Front Glass Panel Replacement: stap 2, afbeelding 1 van 1
    • Once you have freed all the plastic clips, pull the back case off the Kindle Fire.
    Vraag FixBot
    Voeg opmerking toe
  3. Kindle Fire Front Glass Panel Replacement, Battery: stap 3, afbeelding 1 van 3 Kindle Fire Front Glass Panel Replacement, Battery: stap 3, afbeelding 2 van 3 Kindle Fire Front Glass Panel Replacement, Battery: stap 3, afbeelding 3 van 3
    • Fit the tip of the plastic opening tool between the right battery cell and the Kindle Fire's frame.
    • Lever the battery up and work the plastic opening tool down along its edge to release the glue securing it to the frame.
    Vraag FixBot
    Voeg opmerking toe
  4. Kindle Fire Front Glass Panel Replacement: stap 4, afbeelding 1 van 1
    • Repeat the process from the previous step to free the left battery cell.
    Vraag FixBot
    Voeg opmerking toe
  5. Kindle Fire Front Glass Panel Replacement: stap 5, afbeelding 1 van 2 Kindle Fire Front Glass Panel Replacement: stap 5, afbeelding 2 van 2
    • Lift the back of the battery up to relieve any tension in the battery connector and simultaneously use a spudger to push the battery connector out of its socket.
    • Pull the battery out of the Kindle Fire.
    Vraag FixBot
    Voeg opmerking toe
  6. Kindle Fire Front Glass Panel Replacement, Speaker Assembly: stap 6, afbeelding 1 van 3 Kindle Fire Front Glass Panel Replacement, Speaker Assembly: stap 6, afbeelding 2 van 3 Kindle Fire Front Glass Panel Replacement, Speaker Assembly: stap 6, afbeelding 3 van 3
    • Peel the tape on the upper-left IC that is securing the speaker cable.
    • Use the flat end of a spudger to push the speaker connector out of its socket.
    • Deroute the speaker cable.
    Vraag FixBot
    Voeg opmerking toe
  7. Kindle Fire Front Glass Panel Replacement: stap 7, afbeelding 1 van 2 Kindle Fire Front Glass Panel Replacement: stap 7, afbeelding 2 van 2
    • Remove the two 3.3 mm Phillips #00 screws securing the speakers to the Kindle Fire.
    • Lift the speakers out of the Kindle Fire.
    Vraag FixBot
    Voeg opmerking toe
  8. Kindle Fire Front Glass Panel Replacement, Motherboard: stap 8, afbeelding 1 van 3 Kindle Fire Front Glass Panel Replacement, Motherboard: stap 8, afbeelding 2 van 3 Kindle Fire Front Glass Panel Replacement, Motherboard: stap 8, afbeelding 3 van 3
    • Remove the two 2.3 mm Phillips #00 screws from the touchscreen controller.
    • Use a plastic opening tool to release the touchscreen controller connector.
    • Gently remove the touchscreen controller by lifting it up and to the right.
    • Be careful not to rip the ribbon cable in doing so.
    Vraag FixBot
    Voeg opmerking toe
  9. Kindle Fire Front Glass Panel Replacement: stap 9, afbeelding 1 van 3 Kindle Fire Front Glass Panel Replacement: stap 9, afbeelding 2 van 3 Kindle Fire Front Glass Panel Replacement: stap 9, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    • Use a plastic opening tool to flip open the power button ZIF connector.
    • This connector will not be removed until the motherboard is free.
    • Flip open the ambient light sensor ZIF socket with a plastic opening tool.
    • Use a pair of tweezers to pull the blue tab on the ambient light sensor cable to remove it from its socket.
    Vraag FixBot
    Voeg opmerking toe
  10. Kindle Fire Front Glass Panel Replacement: stap 10, afbeelding 1 van 3 Kindle Fire Front Glass Panel Replacement: stap 10, afbeelding 2 van 3 Kindle Fire Front Glass Panel Replacement: stap 10, afbeelding 3 van 3
    • Use a plastic opening tool to lift up and disconnect the display data cable.
    • Lift up on the antenna connector with a plastic opening tool to disconnect it.
    • De-route the antenna cable.
    Vraag FixBot
    Voeg opmerking toe
  11. Kindle Fire Front Glass Panel Replacement: stap 11, afbeelding 1 van 1
    • Remove the six 2.6 mm Phillips #00 screws securing the motherboard to the frame.
    Vraag FixBot
    Voeg opmerking toe
  12. Kindle Fire Front Glass Panel Replacement: stap 12, afbeelding 1 van 3 Kindle Fire Front Glass Panel Replacement: stap 12, afbeelding 2 van 3 Kindle Fire Front Glass Panel Replacement: stap 12, afbeelding 3 van 3
    • Use a plastic opening tool to gently lever up the bottom side of the motherboard to free from the adhesive on its underside.
    • Lever the top side of the motherboard up with a plastic opening tool until it comes free.
    • Lift the motherboard out of the Kindle Fire, making sure that the power button cable from step 8 comes free from its connector.
    Vraag FixBot
    Voeg opmerking toe
  13. Kindle Fire Front Glass Panel Replacement, Power Button Board: stap 13, afbeelding 1 van 2 Kindle Fire Front Glass Panel Replacement, Power Button Board: stap 13, afbeelding 2 van 2
    • Remove the 2.5 mm Phillips #00 scew securing the power button board to the Kindle Fire.
    • Lift the power button board out of the Kindle Fire.
    Vraag FixBot
    Voeg opmerking toe
  14. Kindle Fire Front Glass Panel Replacement, Frame Loosening: stap 14, afbeelding 1 van 3 Kindle Fire Front Glass Panel Replacement, Frame Loosening: stap 14, afbeelding 2 van 3 Kindle Fire Front Glass Panel Replacement, Frame Loosening: stap 14, afbeelding 3 van 3
    • Use the flat end of a spudger to peel the ambient light sensor cable off of the frame.
    • You will need to peel up the silver tape in the cable's lower right bend. The silver tape under the lower left bend of the cable does not need to come up with it.
    Vraag FixBot
    Voeg opmerking toe
  15. Kindle Fire Front Glass Panel Replacement: stap 15, afbeelding 1 van 1
    • Use the flat end of a spudger to peel up the silver tape securing the antenna cable.
    Vraag FixBot
    Voeg opmerking toe
  16. Kindle Fire Front Glass Panel Replacement: stap 16, afbeelding 1 van 1
    • Remove the five 3.6 mm Phillips #00 screws securing the frame and ambient light sensor.
    Vraag FixBot
    Voeg opmerking toe
  17. Kindle Fire Front Glass Panel Replacement, Ambient Light Sensor: stap 17, afbeelding 1 van 1
    • Slide the ambient light sensor out from under the frame and remove it from the Kindle Fire.
    • If the ambient light sensor will not easily come out, slightly lift the frame with a plastic opening tool to allow it to come free.
    Vraag FixBot
    Voeg opmerking toe
  18. Kindle Fire Front Glass Panel Replacement, Frame: stap 18, afbeelding 1 van 3 Kindle Fire Front Glass Panel Replacement, Frame: stap 18, afbeelding 2 van 3 Kindle Fire Front Glass Panel Replacement, Frame: stap 18, afbeelding 3 van 3
    • Use the flat end of a spudger to lever the frame away from the display assembly until you can grab it with your hand.
    • Lift near the retaining tabs marked by red rectangles in the first picture.
    • Remove the frame from the display assembly.
    • While removing the frame there may be sticky residue that will generate some resistance to the detachment of the top half of the frame.
    Vraag FixBot
    Voeg opmerking toe
  19. Kindle Fire Front Glass Panel Replacement, LCD: stap 19, afbeelding 1 van 3 Kindle Fire Front Glass Panel Replacement, LCD: stap 19, afbeelding 2 van 3 Kindle Fire Front Glass Panel Replacement, LCD: stap 19, afbeelding 3 van 3
    • Remove the four 2.4 mm Phillips #00 screws attaching the LCD to the front glass panel.
    • Rotate the top of the LCD 90 degrees away from the front glass panel as shown in the second picture.
    • Rotate the LCD and front glass panel slowly so you don't damage the antenna on the bottom of the LCD.
    • Separate the LCD and front glass panel.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
85 andere personen hebben deze handleiding voltooid.
Phillip Takahashi
87.893 Reputatie
87 handleidingen geschreven
25Gids Commentaar
How long does this take?
Dan Joyce - Antwoord Deel
How does that tell you how to fix the screen you are just putting the screen on so it sill cracked so how are you going to fix it now?
Morgan Gregory - Antwoord Deel
This took me about an hour from start to finish - taking my time to mark all the screws etc. but it may take longer if you don't have the correct tools. I agree that there should be a photo of separating the front glass digitizer from the front bezel as the true last step - it can be tricky, and the replacements I have seen don't include the front bezel. I used a razor/hobby knife to slowly peel and separate the digitizer working slowly and carefully from the inside bottom (around and behind the power button cutout) - some goo-gone or lighter fluid will be necessary to clean any old adhesive residue from the bezel as well. The front bezel has a rubberized gasket that should not be remover, so take care to see that you are not peeling that off. My last suggestion is to wear latex or nitrile gloves to prevent getting smudges on the LCD or digitizer during replacement; put them on for step 18, and until you have the frame back in place - care to keep dust out from in between during reassembly is a must!
revere521 - Antwoord Deel
I agree this was difficult, I used 3 different explanations/videos and this was the easiest to follow due to still frame. Thanks for sharing. It took longer than I expected but I did it
kasey - Antwoord Deel
How do I know which part I need?? Do I need the lcd screen and/or the digitizer?? What's the difference?? My kindle was dropped unfortunately and I am trying to find the part to replace it with. PLEASE HELP!! People are trying to charge me 100$ to replace the screen alone, excluding labor.
stefani - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 5
Afgelopen 7 dagen: 20
Afgelopen 30 dagen: 82
Altijd: 227,784
