Ga door naar hoofdinhoud
Kindle Fire Back Case Replacement
Wat je nodig hebt
  1. Kindle Fire Back Case Replacement, Back Case: stap 1, afbeelding 1 van 3 Kindle Fire Back Case Replacement, Back Case: stap 1, afbeelding 2 van 3 Kindle Fire Back Case Replacement, Back Case: stap 1, afbeelding 3 van 3
    • Wedge a plastic opening tool into the lower right corner of the Kindle Fire.
    • Pry the case apart and run the plastic opening tool along the perimeter of the Kindle Fire to release the clips securing the case halves to each other.
    • If you are having extreme difficulty inserting the plastic opening tool, carefully use a metal spudger to undo the first clip, then switch back to the opening tool to avoid scratching your case.
    • It is helpful to pry the bottom of the Kindle Fire away (and out from the side) from the top part. Exerting too much force attempting to split the two without pulling away can cause the tabs on the inside to crack.
    Vraag FixBot
    Voeg opmerking toe
  2. Kindle Fire Back Case Replacement: stap 2, afbeelding 1 van 1
    • Once you have freed all the plastic clips, pull the back case off the Kindle Fire.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
14 andere personen hebben deze handleiding voltooid.
Phillip Takahashi
87.893 Reputatie
87 handleidingen geschreven
3Gids Commentaar
Simple to follow instructions .
Eric Rester - Antwoord Deel
where to buy the base panel for my kindle fire 7 tablet
Senthilvel Murugesan - Antwoord Deel
I was wondering why my kindle case was opening/separating and it was not charging. I opened the case per you instructions and found that the battery has expanded inside ITS case! I hope to be able to get another battery cheaply. Thank you for your help!!
Ellen De - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 22
Afgelopen 30 dagen: 81
Altijd: 17,494
