Ga door naar hoofdinhoud
Kindle 7th Generation Motherboard Replacement
Wat je nodig hebt
    1. Kindle 7th Generation Motherboard Replacement, Front Panel: stap 1, afbeelding 1 van 2 Kindle 7th Generation Motherboard Replacement, Front Panel: stap 1, afbeelding 2 van 2
      • Power off your Kindle before beginning disassembly.
      • At each corner, use the blue plastic opening tool to unhook and separate the front panel from the adhesive.
      • Run the tool along the seams to pry open the front panel.
      Vraag FixBot
      Voeg opmerking toe
    2. Kindle 7th Generation Motherboard Replacement: stap 2, afbeelding 1 van 1
      • Peel the front panel off to remove it from the Kindle.
      • If this is the first time the front panel has been removed, the adhesive may require a significant amount of force to undo.
      • To prevent damaging the front panel, peel the panel from the corners towards the middle of the Kindle.
      • When reassembling your device, if you are replacing the front panel, additional adhesive may be required.
      Vraag FixBot
      Voeg opmerking toe
    1. Kindle 7th Generation Motherboard Replacement, Back Panel: stap 3, afbeelding 1 van 2 Kindle 7th Generation Motherboard Replacement, Back Panel: stap 3, afbeelding 2 van 2
      • Remove the ten 5.0 mm T5 Torx screws.
      • A magnetized screw mat can help you keep track of your screws.
      Vraag FixBot
      Voeg opmerking toe
    2. Kindle 7th Generation Motherboard Replacement: stap 4, afbeelding 1 van 1
      • Working evenly along the corners and edges, separate the internal contents from the back panel.
      • There are many clips securing the screen to the back panel. Force will be required to remove the back, but you should never feel that the Kindle may break.
      Vraag FixBot
      Voeg opmerking toe
    1. Kindle 7th Generation Motherboard Replacement, Motherboard: stap 5, afbeelding 1 van 2 Kindle 7th Generation Motherboard Replacement, Motherboard: stap 5, afbeelding 2 van 2
      Gereedschap gebruikt in deze stap:
      • Flip the screen over to face the motherboard and battery pack.
      • Use the blunted precision tweezers to gently unclip and detach the cable connecting the battery pack and motherboard.
      Vraag FixBot
      Voeg opmerking toe
    2. Kindle 7th Generation Motherboard Replacement: stap 6, afbeelding 1 van 3 Kindle 7th Generation Motherboard Replacement: stap 6, afbeelding 2 van 3 Kindle 7th Generation Motherboard Replacement: stap 6, afbeelding 3 van 3
      • Use the tip of the spudger to flip up the small retaining flap on the copper colored zero insertion force (ZIF) connector.
      • Make sure to flip up the flap and not the connection itself.
      • Pull the cable from the connector.
      • No force is required to do this, as the name, ZIF, implies.
      Vraag FixBot
      Voeg opmerking toe
    3. Kindle 7th Generation Motherboard Replacement: stap 7, afbeelding 1 van 2 Kindle 7th Generation Motherboard Replacement: stap 7, afbeelding 2 van 2
      • Similar to the previous step, flip up the retaining flap on the white cable connector.
      • Pull the white cable from the connection.
      • During reassembly, make sure the retaining flaps for both the white and copper colored cable connections are secured. As these are zero insertion force connections, the cables could potentially slide out if this is not done.
      Vraag FixBot
      Voeg opmerking toe
    4. Kindle 7th Generation Motherboard Replacement: stap 8, afbeelding 1 van 2 Kindle 7th Generation Motherboard Replacement: stap 8, afbeelding 2 van 2
      • Disconnect the touch digitiser bridge cable by using your Spudger to lift up the white tabs on both connectors.
      • Use tweezers to pull out the cable.
      • The touch digitiser bridge cable is the one connecting between these two connectors.
      Vraag FixBot
      Voeg opmerking toe
    5. Kindle 7th Generation Motherboard Replacement: stap 9, afbeelding 1 van 2 Kindle 7th Generation Motherboard Replacement: stap 9, afbeelding 2 van 2
      • Use the T5 Torx screwdriver to remove the eight 3.0 mm Torx screws.
      • Some screws have washers associated with them. It is important to keep track of the washers and remember which thread they came from.
      Vraag FixBot
      Voeg opmerking toe
    6. Kindle 7th Generation Motherboard Replacement: stap 10, afbeelding 1 van 1
      • Remove the motherboard.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
4 andere personen hebben deze handleiding voltooid.
Michael Griffith
485 Reputatie
1 Handleiding geschreven
Cal Poly, Team 6-28, Amido Winter 2015 Lid van Cal Poly, Team 6-28, Amido Winter 2015
CPSU-AMIDO-W15S6G28
4 Leden
26 handleidingen geschreven
3Gids Commentaar
This doesn’t look like my 7th generation. Close but not quite the same. Does the motherboard have to be removed to replace the screen?
Shonna Partlow - Antwoord Deel
Anyone know where to buy parts? I’m struggling to find any
Adrianne - Antwoord Deel
yes this is Def not the same as my 7th gen but it's an 8 inch so maybe that's the difference.. all I see is 4 screws holding down the motherboard n I've removed them but still can't get the board loose.. it's like one side of it is held down under these plastic tabs that don't move..
Heather Hodge - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 137
Altijd: 8,987
