Ga door naar hoofdinhoud
Kindle 7th Generation Back Panel Replacement
Wat je nodig hebt
    1. Kindle 7th Generation Back Panel Replacement, Front Panel: stap 1, afbeelding 1 van 2 Kindle 7th Generation Back Panel Replacement, Front Panel: stap 1, afbeelding 2 van 2
      • Power off your Kindle before beginning disassembly.
      • At each corner, use the blue plastic opening tool to unhook and separate the front panel from the adhesive.
      • Run the tool along the seams to pry open the front panel.
      Vraag FixBot
      Voeg opmerking toe
    2. Kindle 7th Generation Back Panel Replacement: stap 2, afbeelding 1 van 1
      • Peel the front panel off to remove it from the Kindle.
      • If this is the first time the front panel has been removed, the adhesive may require a significant amount of force to undo.
      • To prevent damaging the front panel, peel the panel from the corners towards the middle of the Kindle.
      • When reassembling your device, if you are replacing the front panel, additional adhesive may be required.
      Vraag FixBot
      Voeg opmerking toe
    1. Kindle 7th Generation Back Panel Replacement, Back Panel: stap 3, afbeelding 1 van 2 Kindle 7th Generation Back Panel Replacement, Back Panel: stap 3, afbeelding 2 van 2
      • Remove the ten 5.0 mm T5 Torx screws.
      • A magnetized screw mat can help you keep track of your screws.
      Vraag FixBot
      Voeg opmerking toe
    2. Kindle 7th Generation Back Panel Replacement: stap 4, afbeelding 1 van 1
      • Working evenly along the corners and edges, separate the internal contents from the back panel.
      • There are many clips securing the screen to the back panel. Force will be required to remove the back, but you should never feel that the Kindle may break.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
4 andere personen hebben deze handleiding voltooid.
Abby Roulier
1.167 Reputatie
3 handleidingen geschreven
Cal Poly, Team 6-28, Amido Winter 2015 Lid van Cal Poly, Team 6-28, Amido Winter 2015
CPSU-AMIDO-W15S6G28
4 Leden
33 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 21
Afgelopen 30 dagen: 104
Altijd: 6,392
