Ga door naar hoofdinhoud
Kidzlane Walkie-Talkie Antenna Replacement
Wat je nodig hebt
  1. Kidzlane Walkie-Talkie Antenna Replacement, Antenna: stap 1, afbeelding 1 van 1
    • Flip your device over so the back panel is facing up.
  2. Kidzlane Walkie-Talkie Antenna Replacement: stap 2, afbeelding 1 van 2 Kidzlane Walkie-Talkie Antenna Replacement: stap 2, afbeelding 2 van 2
    • Use the Phillips #00 Screwdriver to unscrew the four 4mm screws shown.
    • Take out the three batteries from the device.
  3. Kidzlane Walkie-Talkie Antenna Replacement: stap 3, afbeelding 1 van 2 Kidzlane Walkie-Talkie Antenna Replacement: stap 3, afbeelding 2 van 2
    • Gently separate the front and back panels of the device.
    • Gently remove the green circuit board and the black speaker from the plastic casing.
  4. Kidzlane Walkie-Talkie Antenna Replacement: stap 4, afbeelding 1 van 1
    • Flip the green circuit board over, so that the end of the antenna is visible. Use the soldering iron to disconnect the antenna.
    • Carefully remove the antenna from the circuit board.
    • The antenna may be hot from the soldering device.
Conclusie
To reassemble your Kidzlane Walkie-Talkie, follow these instructions in reverse order.
Amin
642 Reputatie
5 handleidingen geschreven
IUPUI, Team 1-1, Wilson Spring 2016 Lid van IUPUI, Team 1-1, Wilson Spring 2016
IUPUI-WILSON-S16S1G1
4 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 15
Altijd: 1,010
