Wat je nodig hebt
Unlock the battery latch on the right.
Unlock the battery lock on the left.
Remove the battery pack from its slot.
Gently detach the first clip from the bar with the ON / OFF button.
Gently detach the second clip from the bar with the ON / OFF button.
And so on.
To reassemble your device follow the following instructions in reverse order
Met dank aan deze vertalers:
100%
irlanda helpt ons de wereld te repareren! Doe je mee?
Begin met vertalen ›
