Ga door naar hoofdinhoud
Keurig K10 MINI PLUS Handle Replacement
Wat je nodig hebt
  1. Keurig K10 MINI PLUS Handle Replacement, Top Needle: stap 1, afbeelding 1 van 2 Keurig K10 MINI PLUS Handle Replacement, Top Needle: stap 1, afbeelding 2 van 2
    • Remove two 9 mm Phillips #1 screws.
    • Avoid the top needle if at all possible. The needle may cut you and/or penetrate your skin.
    • The screws are located on the top of where the K-Cup would be.
  2. Keurig K10 MINI PLUS Handle Replacement: stap 2, afbeelding 1 van 3 Keurig K10 MINI PLUS Handle Replacement: stap 2, afbeelding 2 van 3 Keurig K10 MINI PLUS Handle Replacement: stap 2, afbeelding 3 van 3
    • Once you remove the screws, the top cover should come out.
    • The back of the cover is held in place by two locking tabs. To remove the cover, pull it back slightly and it should come free.
    • You will then want to remove these screws which are the same size.
    • The needle is sharp, so be careful.
  3. Keurig K10 MINI PLUS Handle Replacement: stap 3, afbeelding 1 van 1
    • Once you get those removed, you are going to want to pull on the hose until it pops off.
    • Once the hose comes off, the needle will fall out by itself.
    • Be careful when picking up the needle as the needle is sharp.
  4. Keurig K10 MINI PLUS Handle Replacement, Handle: stap 4, afbeelding 1 van 1
    • Remove the two Phillips #1 screws.
    • The top needle is intact and there, so be careful when in this area.
  5. Keurig K10 MINI PLUS Handle Replacement: stap 5, afbeelding 1 van 2 Keurig K10 MINI PLUS Handle Replacement: stap 5, afbeelding 2 van 2
    • Next, after the removal of the hose on the top by simply pulling it off, remove the following four Phillips #1 screws.
  6. Keurig K10 MINI PLUS Handle Replacement: stap 6, afbeelding 1 van 1
    • Once you take off the screws, this part of the handle will come off.
  7. Keurig K10 MINI PLUS Handle Replacement: stap 7, afbeelding 1 van 1
    • To pull this part off, pull inwards with the these tabs located on both sides of the handle assembly.
  8. Keurig K10 MINI PLUS Handle Replacement: stap 8, afbeelding 1 van 3 Keurig K10 MINI PLUS Handle Replacement: stap 8, afbeelding 2 van 3 Keurig K10 MINI PLUS Handle Replacement: stap 8, afbeelding 3 van 3
    • Next, remove these two Phillips #1 screws to allow the release of the actual handle from the frame.
    • For the O rings, we used the plastic prying tools. Just keep in mind that you might want to hold one side of the O ring down while trying to pry off the other side with the other.
    • Once you get the O rings on both sides out, you can pull the handle by pulling on each side.
  9. Keurig K10 MINI PLUS Handle Replacement: stap 9, afbeelding 1 van 1
    • Once you pull both sides, the handle will come off as shown.
Conclusie
Roberto Maldonado
395 Reputatie
1 Handleiding geschreven
iFixit, Team 1-1, Weber Winter 2016 Lid van iFixit, Team 1-1, Weber Winter 2016
FIX-WEBER-W16S1G1
4 Leden
37 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 24
Altijd: 2,440
