Ga door naar hoofdinhoud
Kensington Slimblade Trackball Disassembly
Wat je nodig hebt
  1. Kensington Slimblade Trackball Disassembly, Uncover and Remove the Screws: stap 1, afbeelding 1 van 3 Kensington Slimblade Trackball Disassembly, Uncover and Remove the Screws: stap 1, afbeelding 2 van 3 Kensington Slimblade Trackball Disassembly, Uncover and Remove the Screws: stap 1, afbeelding 3 van 3
    • Remove the ball and flip the base over.
    • Take off the rubber feet hiding 4 Phillips (PH1) screws using a spudger.
    • Remove the rubber crown hiding 3 small Phillips (PH0) screws.
    • Remove the seven screws.
  2. Kensington Slimblade Trackball Disassembly, Opening the Case: stap 2, afbeelding 1 van 3 Kensington Slimblade Trackball Disassembly, Opening the Case: stap 2, afbeelding 2 van 3 Kensington Slimblade Trackball Disassembly, Opening the Case: stap 2, afbeelding 3 van 3
    • Using an opening pick, pry up the lower case from the bottom.
    • Tilt the lower case to the left to access the USB cable that is routed through a channel in the lower case.
    • Loosen the cable retainer to free the lower housing.
  3. Kensington Slimblade Trackball Disassembly, Remove the Circuit Board: stap 3, afbeelding 1 van 3 Kensington Slimblade Trackball Disassembly, Remove the Circuit Board: stap 3, afbeelding 2 van 3 Kensington Slimblade Trackball Disassembly, Remove the Circuit Board: stap 3, afbeelding 3 van 3
    • Flip up the retaining lever of the ZIF connector on the horizontal optical sensor.
    • Remove the cable from the connector.
    • Flip up the retaining lever of the ZIF connector on the vertical optical sensor.
    • Remove the 3 Phillips PH0 screws securing the circuit board. They are marked with white circles.
    • Remove the circuit board by carefully lifting with a spudger. Place it on a stable support to dust off the micro contacts.
  4. Kensington Slimblade Trackball Disassembly, Dust the Circuit Board: stap 4, afbeelding 1 van 3 Kensington Slimblade Trackball Disassembly, Dust the Circuit Board: stap 4, afbeelding 2 van 3 Kensington Slimblade Trackball Disassembly, Dust the Circuit Board: stap 4, afbeelding 3 van 3
    • Dust the button contacts by pressing on them with a spudger and blowing into them with a hand blower. Repeat ten to twenty times for each of the four contacts.
    • Remove the screws from the horizontal displacement sensor.
    • Dust the sensor as needed. (This one is surprisingly clean.)
    • Do the same for the vertical displacement sensor.
Conclusie
To reassemble your device, follow the instructions in reverse order.
Één andere persoon heeft deze handleiding voltooid.
Met dank aan deze vertalers:
fr en
100%
Jerry Wheeler helpt ons de wereld te herstellen! Wil je bijdragen?
Begin met vertalen ›
Ludovic
686 Reputatie
4 handleidingen geschreven
Francophones Lid van Francophones
Community
27 Leden
12 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 6
Afgelopen 7 dagen: 16
Afgelopen 30 dagen: 75
Altijd: 998
