Ga door naar hoofdinhoud
Kayak Handle Replacement
Wat je nodig hebt
    1. Kayak Handle Replacement, Handle: stap 1, afbeelding 1 van 1
      • Detach the handle and paracord strap from the kayak.
      Vraag FixBot
      Voeg opmerking toe
    2. Kayak Handle Replacement: stap 2, afbeelding 1 van 3 Kayak Handle Replacement: stap 2, afbeelding 2 van 3 Kayak Handle Replacement: stap 2, afbeelding 3 van 3
      • Insert the screwdriver into the head of the bolt on the bottom side of the handle.
      • Apply pressure to the bottom of the handle.
      • Remove the top part of the handle by using the screwdriver to pop it out.
      • Caution: Do not let the hardware fall into the hull, as it may slide into unreachable areas of the bow or stern.
      Vraag FixBot
      Voeg opmerking toe
    3. Kayak Handle Replacement: stap 3, afbeelding 1 van 2 Kayak Handle Replacement: stap 3, afbeelding 2 van 2
      • Pull the paracord out of the handle so they are separate from each other.
      Vraag FixBot
      Voeg opmerking toe
    4. Kayak Handle Replacement: stap 4, afbeelding 1 van 3 Kayak Handle Replacement: stap 4, afbeelding 2 van 3 Kayak Handle Replacement: stap 4, afbeelding 3 van 3
      • Cut the end of the paracord using your knife or a pair of scissors.
      • Insert the paracord into the bottom side of the handle through the small hole.
      • Pull it through so each side of the paracord is evenly inserted.
      Vraag FixBot
      Voeg opmerking toe
    5. Kayak Handle Replacement: stap 5, afbeelding 1 van 2 Kayak Handle Replacement: stap 5, afbeelding 2 van 2
      • Tie a knot with the paracord using both ends of the already inserted paracord.
      • Pull it tight and be sure that the knot is as close to the edge of the paracord as possible.
      • Cut the excess paracord at the end of the knot if there is any.
      Vraag FixBot
      Voeg opmerking toe
    6. Kayak Handle Replacement: stap 6, afbeelding 1 van 3 Kayak Handle Replacement: stap 6, afbeelding 2 van 3 Kayak Handle Replacement: stap 6, afbeelding 3 van 3
      • Pull the paracord through the handle so that the knot is now inside the handle.
      • Add the cover of the handle back onto the top. Secure it down tightly.
      Vraag FixBot
      Voeg opmerking toe
    7. Kayak Handle Replacement: stap 7, afbeelding 1 van 3 Kayak Handle Replacement: stap 7, afbeelding 2 van 3 Kayak Handle Replacement: stap 7, afbeelding 3 van 3
      • Locate the metal bar on the kayak and place the looped end of the new handle underneath it.
      • Pull the paracord all the way through until the handle stops it.
      • Loop the paracord over the plastic handle.
      • Pull the handle tightly to secure it in place.
      Vraag FixBot
      Voeg opmerking toe
Eindstreep
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 38
Altijd: 241
