Inleiding
This guide shows how to remove and replace the vacuum motor for a Karcher Vacuum Universal 14286230 2014.
When you perform this repair, it is a good opportunity to replace the two rubber motor seals:
- Part 6.903-300.0 (69033000)
- Part 6.903-246.0 (69032460)
Wat je nodig hebt
Carefully lift the motor/filter away from the housing until you can access the motor wires.
You can now fully remove the motor/filter assembly from the housing.
Reassembly tip: Use the alignment tab to help you align the motor/filter with the housing assembly.
Lift the motor flange and remove it from the motor assembly.
Re-assembly tip: Use the marked notch to help you align the motor flange to the assembly.
Peel and remove the two black rubber seals from the motor.
Transfer the rubber seals to the replacement motor.
4 andere personen hebben deze handleiding voltooid.
