Inleiding
This guide shows how to remove and replace the pump for the Karcher Rotary Floor Cleaner 17833080 2017.
If the floor cleaner fails to spray water when activated, check the water distributors behind the roller brushes for clogs first.
Wat je nodig hebt
Press the yellow button near each wheel base to release the wheels.
Remove both wheels from their sockets.
Use a T20 driver to remove the three screws securing the pump cover.
Squeeze the middle plug by the edges and pull it out of its socket.
Lift the pump assembly out of its recess.
Reassembly tip: make sure that the output hose end is fully secured to the housing socket.
Remove the pump.
Reassembly tip: be careful not to mix the pump's input and output. The arrow points towards the pump output, which should connect to the black check valve.
Één andere persoon heeft deze handleiding voltooid.
