Ga door naar hoofdinhoud
Kano Computer Kit Complete Display Board Replacement
Wat je nodig hebt
  1. Kano Computer Kit Complete Display Board Replacement, Display Board: stap 1, afbeelding 1 van 2 Kano Computer Kit Complete Display Board Replacement, Display Board: stap 1, afbeelding 2 van 2
    • Take off the clear backing of the computer and set it aside.
    • The Display board is located in the top right corner of the case.
  2. Kano Computer Kit Complete Display Board Replacement: stap 2, afbeelding 1 van 2 Kano Computer Kit Complete Display Board Replacement: stap 2, afbeelding 2 van 2
    • Always disconnect the battery before performing repairs.
    • Remove the power cable (Circled in red) from the board.
  3. Kano Computer Kit Complete Display Board Replacement: stap 3, afbeelding 1 van 3 Kano Computer Kit Complete Display Board Replacement: stap 3, afbeelding 2 van 3 Kano Computer Kit Complete Display Board Replacement: stap 3, afbeelding 3 van 3
    • Unplug the HDMI cable (Circled in Yellow) from the board
  4. Kano Computer Kit Complete Display Board Replacement: stap 4, afbeelding 1 van 1
    • Unscrew the four 8.5mm screws with your Phillips #1 Screwdriver.
  5. Kano Computer Kit Complete Display Board Replacement: stap 5, afbeelding 1 van 2 Kano Computer Kit Complete Display Board Replacement: stap 5, afbeelding 2 van 2
    • Lift the board off the back of the screen.
    • Be gentle as there is a ribbon cable on the underside that will prevent the board from being removed completely.
  6. Kano Computer Kit Complete Display Board Replacement: stap 6, afbeelding 1 van 2 Kano Computer Kit Complete Display Board Replacement: stap 6, afbeelding 2 van 2
    • Disconnect the white ribbon cable that you find underneath the board.
    • Be careful; it will take some force.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 34
Altijd: 1,296
