Ga door naar hoofdinhoud
K. Preflight Checklist-Motion
  1. K. Preflight Checklist-Motion, Homing X&Y: stap 1, afbeelding 1 van 2 K. Preflight Checklist-Motion, Homing X&Y: stap 1, afbeelding 2 van 2
    • Press Home X. The hot end should move to the left towards the end stop. It will bump the end stop move to the right a few mm, than back left to the end stop and stop.
    • Measure the distance from the edge of the Top X Mount to the edge of the bearing block. Jog the hot end +10mm and re-measure. It should be 10mm larger.
    • Press Home Y. The hot end should move to the back towards the end stop. It will bump the end stop move to forward a few mm, than to the back to the end stop and stop.
    • Measure the distance from the edge of the rear corner to the edge of the bearing block. Jog the hot end -10mm and re-measure. It should be 10mm larger.
    Vraag FixBot
    Voeg opmerking toe
  2. K. Preflight Checklist-Motion, Homing Z: stap 2, afbeelding 1 van 2 K. Preflight Checklist-Motion, Homing Z: stap 2, afbeelding 2 van 2
    • During bed leveling, you want the probe position to be at the center of the bed, not the nozzle. Once you have your X and Y coordinates calculated press Home Z
    • The probe(not the nozzle) will move to the center of the bed, Deploy the probe, raise the bed, stop once the probe is triggered, and lower the bed.
    • If your probe is slightly off center we need to correct it. Manually jog the hotend so the probe is in the center of the bed. Note the coordinates
    • Take the coordinates off the web page and replace them in homez.g and homeall.g
    • G1 X178.75 Y155.2 F10000 ; go to first probe point
    Vraag FixBot
    Voeg opmerking toe
  3. K. Preflight Checklist-Motion, Motion: stap 3, afbeelding 1 van 1
    • Manually jog the hot end
    • When you jog +X it will move to the right
    • When you jog +Y it will move towards the back.
    Vraag FixBot
    Voeg opmerking toe
Eindstreep
David Husolo
9.382 Reputatie
33 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 32
Altijd: 1,374
