Ga door naar hoofdinhoud
Justin Bieber Concert Microphone Speaker Replacement
Wat je nodig hebt
  1. Justin Bieber Concert Microphone Speaker Replacement, Removing back panel: stap 1, afbeelding 1 van 2 Justin Bieber Concert Microphone Speaker Replacement, Removing back panel: stap 1, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    Flathead 1.5 mm Screwdriver
    $5.49
    Koop
    • Remove the back panel of the device by unscrewing the single #8 11.6 mm Flathead screw on the back of the device.
  2. Justin Bieber Concert Microphone Speaker Replacement, Removing batteries: stap 2, afbeelding 1 van 1
    • Remove the 3 AAA batteries from the device.
  3. Justin Bieber Concert Microphone Speaker Replacement, Removing back half of device: stap 3, afbeelding 1 van 2 Justin Bieber Concert Microphone Speaker Replacement, Removing back half of device: stap 3, afbeelding 2 van 2
    • Unscrew the other 4, #8 11.5 mm Phillips head screws to remove the entire back half of the device.
    • Pull apart the device once screws are loose, splitting the device in half.
  4. Justin Bieber Concert Microphone Speaker Replacement, Positioning device: stap 4, afbeelding 1 van 1
    • Keeping all wires connected to their attachments, place the front half of the device face down.
  5. Justin Bieber Concert Microphone Speaker Replacement, Removing speaker: stap 5, afbeelding 1 van 2 Justin Bieber Concert Microphone Speaker Replacement, Removing speaker: stap 5, afbeelding 2 van 2
    • Remove the 2, #8 11.7 mm speaker guard screws with the Phillips Head screw driver.
  6. Justin Bieber Concert Microphone Speaker Replacement, Replacing speaker: stap 6, afbeelding 1 van 1
    • Disconnect the speaker wires from the speaker and replace it with the new one
    • Refer to this guide for help with soldering the wires back onto the speaker.
Conclusie
Mike Seyman
437 Reputatie
4 handleidingen geschreven
Baylor, Team 4-1, Williams Fall 2014 Lid van Baylor, Team 4-1, Williams Fall 2014
BU-WILLIAMS-F14S4G1
3 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 6
Altijd: 181
