Ga door naar hoofdinhoud
Justin Bieber Concert Microphone Printed Circuit Board (PCB) Replacement
Wat je nodig hebt
  1. Justin Bieber Concert Microphone Printed Circuit Board (PCB) Replacement, Removing back panel: stap 1, afbeelding 1 van 2 Justin Bieber Concert Microphone Printed Circuit Board (PCB) Replacement, Removing back panel: stap 1, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    Flathead 1.5 mm Screwdriver
    $5.49
    Koop
    • Remove the back panel of the device by unscrewing the single #8 11.6 mm Flathead screw on the back of the device.
  2. Justin Bieber Concert Microphone Printed Circuit Board (PCB) Replacement, Removing batteries: stap 2, afbeelding 1 van 1
    • Remove the 3 AAA batteries from the device.
  3. Justin Bieber Concert Microphone Printed Circuit Board (PCB) Replacement, Removing back half of device: stap 3, afbeelding 1 van 2 Justin Bieber Concert Microphone Printed Circuit Board (PCB) Replacement, Removing back half of device: stap 3, afbeelding 2 van 2
    • Unscrew the other 4, #8 11.6 mm Phillips Head screws to remove the entire back half of the device.
    • Pull apart the device once screws are loose, splitting the device in half.
  4. Justin Bieber Concert Microphone Printed Circuit Board (PCB) Replacement, Positioning device: stap 4, afbeelding 1 van 1
    • Keeping all wires connected to their attachments, place the front half of the device face down.
  5. Justin Bieber Concert Microphone Printed Circuit Board (PCB) Replacement, Inspecting PCB: stap 5, afbeelding 1 van 1
    • Inspect the printed circuit board for any breaks or cracks.
  6. Justin Bieber Concert Microphone Printed Circuit Board (PCB) Replacement, Removing PCB: stap 6, afbeelding 1 van 2 Justin Bieber Concert Microphone Printed Circuit Board (PCB) Replacement, Removing PCB: stap 6, afbeelding 2 van 2
    • Remove the 2, #8 11.7 mm Phillips Head screws as well as the 2, #8 7.5 mm screws on the printed circuit board.
  7. Justin Bieber Concert Microphone Printed Circuit Board (PCB) Replacement, Replacing PCB: stap 7, afbeelding 1 van 2 Justin Bieber Concert Microphone Printed Circuit Board (PCB) Replacement, Replacing PCB: stap 7, afbeelding 2 van 2
    • Disconnect all wires from the PCB
    • Remove the damaged PCB from the microphone
    • Place new PCB in the Justin Bieber Concert Microphone.
    • Connect all the wires to the new PCB using this soldering guide.
Conclusie
Mike Seyman
437 Reputatie
4 handleidingen geschreven
Baylor, Team 4-1, Williams Fall 2014 Lid van Baylor, Team 4-1, Williams Fall 2014
BU-WILLIAMS-F14S4G1
3 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 9
Altijd: 298
