Ga door naar hoofdinhoud
Justin Bieber Concert Microphone On/Off Switch Replacement
Wat je nodig hebt
  1. Justin Bieber Concert Microphone On/Off Switch Replacement, Removing back panel: stap 1, afbeelding 1 van 2 Justin Bieber Concert Microphone On/Off Switch Replacement, Removing back panel: stap 1, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    Flathead 1.5 mm Screwdriver
    $5.49
    Koop
    • Remove the back panel of the device by unscrewing the single #8 11.6 mm Flathead screw on the back of the device.
  2. Justin Bieber Concert Microphone On/Off Switch Replacement, Removing batteries: stap 2, afbeelding 1 van 1
    • Remove the 3 AAA batteries from the device.
  3. Justin Bieber Concert Microphone On/Off Switch Replacement, Removing back half of device: stap 3, afbeelding 1 van 2 Justin Bieber Concert Microphone On/Off Switch Replacement, Removing back half of device: stap 3, afbeelding 2 van 2
    • Unscrew the other 4, #8 11.6 mm Phillips Head screws to remove the entire back half of the device.
    • Pull apart the device once screws are loose, splitting the device in half.
  4. Justin Bieber Concert Microphone On/Off Switch Replacement, Positioning device: stap 4, afbeelding 1 van 1
    • Keeping all wires connected to their attachments, place the front half of the device face down.
  5. Justin Bieber Concert Microphone On/Off Switch Replacement, Removing PCB: stap 5, afbeelding 1 van 2 Justin Bieber Concert Microphone On/Off Switch Replacement, Removing PCB: stap 5, afbeelding 2 van 2
    • Remove the 2, #8 11.7 mm Phillips Head screws as well as the 2, #8 7.5 mm screws on the printed circuit board.
  6. Justin Bieber Concert Microphone On/Off Switch Replacement, Removing on/off switch: stap 6, afbeelding 1 van 2 Justin Bieber Concert Microphone On/Off Switch Replacement, Removing on/off switch: stap 6, afbeelding 2 van 2
    • Remove the 2, #8 11.7 mm Phillips Head screws on the On/Off Switch Board
  7. Justin Bieber Concert Microphone On/Off Switch Replacement, Replacing on/off switch: stap 7, afbeelding 1 van 2 Justin Bieber Concert Microphone On/Off Switch Replacement, Replacing on/off switch: stap 7, afbeelding 2 van 2
    • Remove On/Off Switch Board from its holding and detach the wires.
    • Replace the On/Off Switch Board with a new one and reattach the wires using this soldering guide
Conclusie
Mike Seyman
437 Reputatie
4 handleidingen geschreven
Baylor, Team 4-1, Williams Fall 2014 Lid van Baylor, Team 4-1, Williams Fall 2014
BU-WILLIAMS-F14S4G1
3 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 2
Altijd: 155
