Ga door naar hoofdinhoud
Jura Impressa C E F models grindstone replacement
  1. Jura Impressa C E F models grindstone replacement, Jura Impressa C E F models grindstone replacement: stap 1, afbeelding 1 van 1
    • The instructions apply to almost all devices from Jura and similar devices from AEG, Krups. The success of the repair is striking!
    • The picture shows the old grind stones on the left and the new ones on the right. They consist of a grinding ring and a grinding cone.
    • For this repair, the side parts do not necessarily have to be removed.
  2. Jura Impressa C E F models grindstone replacement: stap 2, afbeelding 1 van 2 Jura Impressa C E F models grindstone replacement: stap 2, afbeelding 2 van 2
    • Pull the grinder adjuster up. Note the setting, it is best to take a photo of it.
    • The screws that hold the coffee container are located in two recesses. First clean, then loosen. The protective cover over the grinder does not need to be removed.
Conclusie
Follow the steps in reverse order to reassemble your device
Met dank aan deze vertalers:
de en
100%
oldturkey03 helpt ons de wereld te herstellen! Wil je bijdragen?
Begin met vertalen ›
VauWeh
165.841 Reputatie
212 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 5
Altijd: 135
