Inleiding
Sometimes the coffee does not come out of the dispenser, but runs out next to it. The dispenser nozzles may be clogged with coffee grease. It often helps to clean it with pipe cleaners, but sometimes you have to remove the coffee dispenser completely for cleaning or replacement. This is shown here.
Wat je nodig hebt
The instructions are suitable for nearly every model of Jura and similar ones e.g. AEG and Krups.
Remove the water reservoir.
Using an oval head bit you can screw them out. If you haven´t got one you can carefully use pliers. It is a good idea to later change the screws for normal ones.
Beneath both top side covers are two Torx T15 screws. Remove those. Now lift off the whole top cover. Sometimes it jams and you have to use a bit of force.
The side covers must be pushed backwards by about 1 cm. Sometimes this is a little bit difficult to move. If necessary, wedge a plastic opening tool into the gap between the side covers and the front panel. The rear cover can be easily removed.
Remove the four T10 Torx screws that hold the coffee spout to the housing.
In case this has not yet been done, remove the inlet funnel. It is connect by two T10 Torx screws. (This picture shows it already removed)
These are the magnet that hold two metal sliding plates in place. Do not lose those.
With a little bit of force remove the holder from the coffee spout.
The coffee spout can be moved up and down, but must also remain in any position. As a brake, two sliding plates are held in place by magnets on the back of the bracket. Be careful not to lose these magnets.
There are four pins on the back of the coffee spout. Insert these into the corresponding holes in the sliding plates. It is a bit tricky to install and screw the holder and the coffee spout at the same time.
Check whether the spout can be moved against slight resistance and whether it remains in any position.
Danke für die Anleitung. Sie war sehr Hilfreich.
Jura ist die absolute fehlkonstruktion, wie kann man ein Verschleiß teil so katastrophal verbauen wie die brühgruppe, nur profit orientiert auf kosten der verbraucher zum Glück habe ich selber eine saeco durchdacht und genial.
Follow the steps in reverse order to reassemble your coffee machine
7 andere personen hebben deze handleiding voltooid.
Met dank aan deze vertalers:
100%
Deze vertalers helpen ons de wereld te repareren! Wil je bijdragen?
Begin met vertalen ›
7 opmerkingen
Danke,
war sehr hilfreich und hat zum Erfolg geführt!
*******Auf der Rückseite des Kaffeeauslaufs befinden sich vier Stifte. Setze diese in die entsprechenden Löcher in den Gleitblechen ein. Es ist etwas knifflig, den Halter und den Kaffeeauslauf gleichzeitig einzubauen und zu verschrauben.*******
Wenn man die Magnete entfernt hat braucht man nicht alles gleichzeitig zu machen. Zuerst Auslauf, dann denn Halter und dann die zwei Magnete.
So klappt es auch einfacher
Gute Anleitung, das lösen der Arretierung der silbernen Blende könnte etwas detaillierter beschrieben werden.
Vielen lieben Dank, Deine Tipps waren sehr hilfreich und haben zum Erfolg geführt. Ich konnte auch eine Innenreinigung mit dem Staubsauger und Pinsel durchführen.
Prima. Hat gut geklappt.
Wenn die Kabel zu kurz sind, und man nicht die Stecker lösen will, dann
Kann man das vordere Teil auch klappen soweit es die Kabel zulassen.
Dann:
1) das Rohr wo der Schlauch rein geht, abschrauben und es entnehmen
2) Das Teil wo das Rohr rein ging ausklipsen und nach oben entnehmen
3) Es reicht die 4 Torx10-Schrauben , rote Kreise, zu lösen. Klickt man dann den weißen Träger unten aus , da wo die Kabel sind, im Bild ROTER Quader, aus, dann fällt der Auslauf raus.
4) diesen nun innen komplett reinigen und spülen , sodass die 4 Löcher je Kanal komplett frei sind und auf dem Boden kein Kaffeeschmodder mehr
6) Nun umgekehrt zusammen bauen
Danke sehr für Deine Anleitung. Die hat mir die Furcht vordem Gefummel genommen
Freut mich, danke.
VauWeh -
